How to use the ap-16?
I use the HomeWork Board to control the ap-16,
Power supply is 12V 3A,
Circuit diagram and the ap-16 switch, as shown
sd card to store the wav file, such as file
But always show "whoops, no file!" message in the Debug Terminal, as shown
What is wrong with this?
I can play it on my computer.
1. What type of SD card are you using? Some of the cheap cards don't work very well.
2.Are the WAV files (16-bit, PCM, up to 44.1kHz) and stored in FAT or FAT32 format? The AP-16+ plays PCM encoded, 16-bit, stereo WAV files at sample rates up to 44.1kHz. Monophonic files,
or those with a different bit depth, will need to be converted using a freeware program called Audacity and you can it this link http://audacity.sourceforge.net/
The user manual can be downloaded from the Parallax and also can be downloaded from EFX-TEK as well, which covers the use of the AP-16. I will be happy to help you in this forum or you can visit the EFX-TEK support forums where this topic is covered as well and here's the link.
http://www.efx-tek.com/php/smf/index.php?board=28.0
yeah, looking at it he is getting communication with the AP-16. I would say it may be a problem with your file names? Are they the same as in the program?
I use the test program.
SD cards are only two files, as shown.
SD card is "TRANSCEND, 1G", as shown.
The WAV files are (705kbps, 16-bit, PCM, 44.1kHz, 1 channel) and stored in FAT format.
I hope this helps you out. And later on I will post the link where we talked about this on EFX-TEK support forum.
Here is the link to the topic on EFX-TEK support forums that talks about your problem that have.
http://www.efx-tek.com/php/smf/index.php?topic=1637.msg9578#msg9578
Thanks a lot for the info,I will try it.
