SX Video Display Module? — Parallax Forums
PTaylorPTaylor Posts: 12
edited 2011-01-18 16:38 in General Discussion
Seems this is no longer offered. Anything else that can replace it? S schematic with code to build it for NTSC?
I'm looking for something to adapt to a Basic Stamp 2 to display text on a TV screen via composite video.
This is perfect, easy serial interface, plug and go, etc.....
    edited 2011-01-18 08:59
    This little chip may work for you:
    http://www.speechchips.com/shop/item.aspx?itemid=5
    Robert
  • BeanBean Posts: 8,129
    edited 2011-01-18 09:04
    PTaylor, I made them. I should still have a couple lying around.
    I will look and let you know if I find any.
    Bean
  • PTaylorPTaylor Posts: 12
    edited 2011-01-18 09:05
    Thanks, looks promising.
    edited 2011-01-18 09:06
    The Propeller Backpack is intended as a replacement for this (as it comes out of the box) among other things. It has a 3-pin interface (power / ground / serial data) and the installed firmware works as a video terminal. Have a look at the documentation.
    edited 2011-01-18 09:22
    Good call, Mike. The Propeller Backpack has better resolution and has much more capability and flexibility than the older SX video display. I have an SX display and it was fine in its day, but since the Prop backpack is on sale right now for $34, I'd jump on that. I may just have to order one for myself!
    edited 2011-01-18 09:25
    Oh yeah, the backpack is a much better solution. And that is a killer price.
    Go with the backpack instead.
    Bean
    Hey PTaylor. Consider this: Just use a propeller for the whole project. With 8 cores it is as easy as an object declaration to add a video display. It takes 3 resistors to make composite video in color and you can use the PBASIC library in OBEX or something like FemtoBasic or PropBasic (written by Bean above - a propeller derived version of SX/B previously derived from his basic for PICs or something) to aid in the transition. Just a thought.
