A book reader with Prop ?
I have an idea about a book reader with Prop.
First we use a LCD TV or LCD monitor with VGA or TV port as display( from 7 to 12 or may be 14 inch)
Pros : they are cheaper than TFT LCD module,which from 2,5 to 7 inch, and have a larger view.
Cons : heavier ( may use as a muscle training tool
if you read for long time )
Battery: Lion cells from laptop battery.The charger and the pack are ready,we may use one cog of Prop to measure and warning when the battery is low.The battery are for display module and Prop circuit.At least 4 cells,3 for display and 1 for Prop.
Pros: good performance/weight ratio,recycle your wearing laptop battery.
Cons: need a charger
Prop circuit: Read txt file from a SD card and display through VGA port,change pages buttons,a GUI for select txt files.Maybe read image (for example .bmp image) ,display them so that we can read manga,comic books,or some university text book with many figures (convert these books from .pdf file to images ),if the Prop stile has some room, integrated a MP3 player so that we can listen to music while reading
Pros : sound interesting
and the text part seems in the reach.
Cons: the image part still no clear ideal,"RGB burger" seems to be promising but it is canceled.
I have done the charger for the Li-on cells and it work fine,auto shutdown when full.
I still learn the SPIN and can do some thing with the text.
I welcome all the suggestions,advice,etc.(especially in image part,i really want that function )
Thank you all for reading
There, I said it. Now, given that many supposedly impossible things have been achieved with the Prop, from software defined radio to USB host controller, you have a very good chance of making it work in some fashion:)
* I'd look for a display which has it's own RAM. There are 3,5" displays out there which are not to expensive. I have one with resistive touch screen running. There also exist 7" systems but these are more expensive.
* Plan B, build a display system by yourself. RAM could directly drive the digital input lines of a display (the RGB lines), the rest is done by propeller. As the access to this RAM is sequential you don't need a lot of propeller PINs when you use a counter which loops through RAM.
Having 2 of these sub-systems you can switch between filling RAM with content from SD and displaying the content.
* MP3 is doable with a dedicated MP3 decoder-chip.
This would be a fun project, as you could achieve this goal much cheaper by buying an Android device, for example the Archos 7 which is available in a slightly older version for ~ $150.
Thank you all
The Android or other system is hard to find in my country and its price after tax,shiping is about 180-200$.For student and high school student,one need them most that is almost out of reach.and of course it is fun if we DIY
@MagIO2 :The small display like 2,5' or 3,5' with memory display are available but this is too small when we read comic book and textbook,as eg. "Machine design" of Norton.
The PlanB is what i am researching now,i have seen some ways like RGB burger or CPLD display,even a AVR VGA system of AtomicZombie from AVR freaks,but these projects are either canceled or not wanted resolution.
@Dr_Acula: For text i think 2 colors are enough because the books with figures,images i will consider as images.The displays i choosed are the 2hd LCD monitors that i can have with around 30$.The smaller like 3,5' or 5' are equal or more expensive(in my country).I thought we will wish together so that Santa will activate a mass production of display in North Pole so that its price will reduce to 30$
@Heater. Thank you for cheering me
http://tinyvga.com/avr-sdram-vga.This is the project i found on net from last year,the resolution seem good and the image seem clear enough for reading.
The schematic misses two components,but i suggest these are a RAMDAC and a delay line.
Any way i will star with the text first and then add image later.
Of course if you only want text in two color, the propeller can do that now.
The RAMDAC according to what i have found can be 24bit color,they range from 6bit to 24bit
The text is for some classical books like books of June Verne,Alexander Duma,etc so i thought they only need black character on white background.Others like Make magazines,i thought can be display as images,that is better for viewing.
http://www.xfree86.org/3.3.6/S34.html
here is a list of RAMDAC,i found another list that has more and has description but lost the link somewhere :P
http://www.lucidscience.com/pro-vga%20video%20generator-1.aspx
here is the link of Atoniczombie AVR video generator
Sorry to frighten you.
It is something of a tradition here on the Prop forum that proposals are made for Propeller projects and immediately a dozen posts will point out that whatever it is impossible on the Prop and that there are better chips to do it with. "The Prop" is too slow or "the Prop does not have enough memory", "better to use an ARM" etc etc.
Then someone turns up an with a Prop implementation. The impossible becomes possible:) Like the USB nost controller for example.
Often it requires rethinking what it is you are actually trying to do. Accepting lesser speed or features than one would normally expect. Or just being damn clever:)
I'm sure if you create the video system you have in mind many people would be very happy. E-book reader or not:)
thank you, i will try "deny the destiny"
