Removing BAD Attachment
Hi all.
It is nice to have possibility to Post attachment's BUT how I can remove one if BADLY posted.
LOOK at this thread
One of Attachment's are BAD.
1 one and need be removed
LOOK at this thread
But I digress, if you enter the Attachment Manager (edit post, go advanced, scroll down and enter attachment manager) then you will be welcomed by a new window that's broken up into a few panes.
Header Pane, Folder Pane, Home Pane, and Attachment Pane.
All of the documents/files made available to any specific post will appear as thumbnails in the Attachment Pane. You will also notice a square block that can be checkbox toggled on/off, and that will allow you to remove additional erroneous attachments.
Now that that's said... I'll make some images and test it in different browsers as a follow up.
Click to enter:
All loaded images/documents/files will appear in the lowest pane. When you hover over the thumbnail a few additional options will become available so that you can either insert it, delete it, and more.
Hope this helps.
Big Thanks. That little X I have missed on this thumbnail. Maybe it is possible to add some info like Line "Drag previously
" for ones that can have problems that me?
