Parallel cogs and controlling the same output.
I created a simple program to read a switch and either turn on or off the output to a relay (LED) on prop demo board. When you turn the LED on,hold it on for two seconds, to simulate that the relay will be on for about 30 seconds after you press the go button. But I want to always scan for the stop switch, so based on the lab example I started my first cog and that's called switchcaller, it launches LEDonoff just fine, but I can't seem to interrupt the 2 seconds of waitcnt in the cog running LEDonoff. The method lab relaunches the second cog and that stops the program as near as I can tell, but why can't you just make a new call from the main cog and force a stop? Is there a better method?
Dave
LEDonoff.spinSwitchcontroller.spin
Dave
I see my mistake on not getting to HardOff and LEDoff in my first program. Thanks. I still get caught in those simple mistakes, originally, I didn't have it written as a method and then I was trying to make it more proper. The functional answer here is that the outputs are ORed. I understand that I can't turn off the output from the first cog, but maybe I am fundamentally not understanding something about cogs here. Once I launch this LEDonoff in it's own cog, aren't any calls to it also acting within the launched cog? That's why I put in a call to LEDoff in LEDonoff from switchcaller, but I do think it waits for the waitcnt to complete before it processes anything.
I can put in the main calling program to start the LEDonoff cog again and it turns the LED off immediately, but I guess I am wonder if that isn't the best way to cause the output to go low. As a hardware guy, it works, but I wonder if there's a better way. Switchcontroller1.spinLEDonoff.spin
Is there a better method to have a pin go high and then stay high for a time period unless another switch is pressed? I can do this in hardware just fine, but really hoping to learn the software.
Dave
pri oneshot(pin, ms, kill) | t ' launch with cognew '' One-shots pin (output) for ms milliseconds '' -- if kill (input) goes high, output aborted '' -- runs in own cog, unloads itself dira[pin] := 1 outa[pin] := 1 t := cnt repeat ms if (kill => 0) and (ina[kill] == 1) quit waitcnt(t += (clkfreq / 1_000)) outa[pin] := 0 cogstop(cogid)The idea is that you can call this will an pin # for the output, the # of milliseconds to run, and a pin # for the kill input (-1 for no kill pin). The output will stay hight for the target milliseconds unless the kill input goes high, then it gets terminated immediately. Once the loop is done the output goes low and the cog is unloaded. You'll need to create a small stack array (32 longs will be plenty) and call it like this
This is, in effect, a software 555 in one-shot mode with the kill input attached to the 555 reset pin.
if you launch another cog with a SPIN-method then the SPIN-interpreter is loaded into this cog and starts executing the code specified in the cognew-statement.
This means the interpreter fetches the SIN-bytecode at the adress of speciefied code and goes on from there following the "execution-path" coded from there.
You still can call the same method from all other cogs and then each cog will fetch the SIN-bytecodes end execute it independently from all other cogs.
If you just wnat an output pin to be high until another switch is pressed this could simply be a repeat loop with an if-condition.
But I think you want to do more. So you have to provide a description what you want to do IN THE END.
Believe me - in most cases - as soon as the forum knows what should be done "in the end" good and sometimes completly different solutions will be found.
best regards
Stefan
Thanks, that's pretty clever. So what I would do for my implementation is launch this when my start button is depressed, which will turn it on for whatever delay I have passed in milliseconds. If I wanted a dynamic reset while the program is running I think I could call the cognew again and then kill this cog by it's cogid, in effect taking advantage of the wired or logic that made my first attempt not too successful.
@StefanL38, What I want to do, I have a start button and a stop button on one of my sculptures. The start button drives a relay which runs a 90VDC motor on a conveyor. It takes about 30 seconds for the conveyor to move little people from one side to the other. So after 30 seconds, I need a timeout condition to stop the belt. The one condition which has to override this activity is if the stop button is pressed. But I would like it if that was a soft stop, meaning you could start it right back up, if the button was pressed by mistake for example, you could press the start button and be running right again.
My little programs above do that, but I didn't think they were correct programming wise.
CON _xinfreq = 5_000_000 _clkmode = xtal1 + pll16x input_pin = 4 VAR long stack[40] PUB main dira[input_pin] := 0 ' set to an input line repeat if ina[input_pin] == 1 ' check for high or low cognew(oneshot(18, 2000, 3), @stack) ' call this subroutine in a new cog. pri oneshot(pin, ms, kill) | t ' launch with cognew '' One-shots pin (output) for ms milliseconds '' -- if kill (input) goes high, output aborted '' -- runs in own cog, unloads itself dira[pin] := 1 ' sets as an output outa[pin] := 1 ' sets output high ' dira[kill] := 0 ' sets as an input no difference t := cnt repeat ms if (kill => 0) and (ina[kill] == 1) ' If kill is non-zero and the pin is high 'outa[pin] := 0 ' then quit loop immediately quit ' wait a millisecond waitcnt(t + (clkfreq / 1_000)) outa[pin] := 0 'once you have repeat the number of ms, turn off LED cogstop(cogid) ' stop cogAnd 2 seconds is fine, as you call the function with 2000ms = 2s. If it glows somewhat about 54 seconds this means that the counter already had a value bigger than the value you want to wait for in the waitcnt. So, maybe you should not do the division in waitcnt. Simply calculate the delta in front of your loop and then you can simply add in the waitcnt.
delta := clkfreq / 1000
t := cnt + delta
repeat
oh ... wait ... now I have it
waitcnt( t += clkfreq/1000 ) is the fix you need ;o)
Sorry for this confusing post, but I'm doing brain-debugging, as I don't have a prop near to test. .... and it's early in the morning ;o)
Which is already in the code!
I am with MagIO, though, you might as well start a cog and leave it running. What I think may be happening is that you program is in fact starting multiple cogs. You could prevent this by checking the relay output pin for activity before using cognew with the oneshot method.
Or you could just let a relay control method run and be activated by giving it some time (this would be a global variable). Here's the idea:
pri relayctrl(rlypin, mspntr, killpin) | t outa[rlypin] := 0 ' output and off dira[rlypin] := 1 dira[killpin] := 0 ' input t := cnt ' sync timing repeat if (ina[killpin] == 1) ' check kill pin long[mspntr] := 0 outa[rlypin] := (long[mspntr] > 0) ' on if still running waitcnt(t += (clkfreq / 1_000)) ' wait 1ms if (long[mspntr] > 0) ' running? long[mspntr] -= 1 ' yes, decrementYou could call it at the top of your program like this:
... where RELAY_PIN and KILL_PIN are constants for those pins (they don't change, right?) and relayms is a global variable (long) that holds the output timing in milliseconds. A positive, non-zero value in relayms will activate the relay. The kill input actually clears this variable which is used to disable the output. Your code might look something like this:
repeat if (ina[TRIGGER] == 1) ' trigger active? relayms := 2_000 ' yes (re)start timerThis will start the relay. Once the trigger input goes away the relay will run for another 2000 milliseconds (2s).
I can see that multiple cogs would cause the LED to stay lit. I'll work on this code tonight and let you all know what I find out. Thanks so much, I'm still swimming in using SPIN.
@MagIO2, thank you also. Your idea made me understand the code JonnyMac posted.
