Prop Based Phone Dialer...Message Player? — Parallax Forums
CassLanCassLan Posts: 586
edited 2011-01-18 20:35 in Propeller 1
Is anyone aware of an available prop-based phone dialer which would allow the playing of recordings stored on SD Card?
    edited 2011-01-14 09:12
    I don't know if they are Prop Based... but, I am well aware of them...Half a dozen recorded sales pitches per day.
    why would You want one???
    scratch that, it is none of My business..
    Deamon Dialers were the cause of My first run in with the law.. use them wisely..
  • Kevin CookKevin Cook Posts: 159
    edited 2011-01-14 09:14
    The AP-16 is a fast way to run audio files off the SD card. This product is one way to do what you want. Its part number is 31316.
  • idbruceidbruce Posts: 6,197
    edited 2011-01-14 09:44
    Hello Everyone
    I am interested in something similar. I want to hook up a modem/fax or whatever to send out a text message. For example, if there is a machine error, I want to send a text message to a cell phone indicating that an error has occured and what the error was.
    Bruce
  • Forest GodfreyForest Godfrey Posts: 38
    edited 2011-01-14 14:08
    For the text-message based thing, you should check out Sparkfun's cell-phone modules: http://www.sparkfun.com/categories/69 You can either get one of the serial-interface modules and hook it up to a Prop or use one of their modules with a microcontroller already on it (which, I suppose, you could *also* hook up to a Prop :)
    edited 2011-01-14 15:57
    Forest Godfrey
    Thanks for the link, which resulted in a quest for more information. From what I have discovered, to be able to hook up to a cellular network and send sms messages, you need a gsm type modem. I was hoping this could be done with a regular land line.
    Bruce
  • CassLanCassLan Posts: 586
    edited 2011-01-17 21:47
    basiclly a job has fallen into my lap, and Im very excited about it.
    its the monitoring of some hvac alarms for various limits based on temp, humidity..etc
    the boiler mechanic 2 years ago made this slick box with a touch screen (operator interface) a PLC and some dialer. Well the guy who was supposed to program everything never got it working aside from the guys logo being displayed on the screen.
    anyhow, I will use the dialer that is already there, the PLC will be replaced with a C3 :).
    im still not sure if Im going to replace the touch screen, its a serial device with its own IO...it gets programmed from a PC...It could probably do the job that the PLC was supposed to do. However, it costs about 1,000 bucks....and it seems like a waste of $$ to purchase one so I could write a driver for it.
    Yeah...it looks like its all going to be replaced. I'll let you guys know how it turns out :)
    edited 2011-01-18 01:09
    The state of that project that you have inherited sound just the same as that cartoon strip "I have no idea how to design apower supply, so I have hammered a nail into a piece of wood. I am on leave now but ...."
    edited 2011-01-18 06:45
    Yeah Toby, that's kind of how it went.
    The nice thing for me is that its an auxilary project, one which I will enjoy doing as well. So there is not allot of pressure/deadlines for me...Yay!!
    edited 2011-01-18 17:20
    Gee, I built a phone answer/switch/musiconhold for households in late 90's but it wasn't successful. I cannot recall if it could dial (dtmf chip? - it had a DTMF detector chip) but it was approved for Oz/NZ. It provided the isolation and had an input for a radio (or whatever) which did not require approval. Pretty sure I chucked the pcbs.
    I could get a new lot of pcbs but not sure about the interest in such an interface. PCB is 50x60mm. Not sure if all parts are still available and although a micro controls it, there is no interface to it. Just checked, DTMF detection only with CM8870 chip.
    I have started a new thread here http://forums.parallax.com/showthread.php?128867-Interfacing-the-Prop-to-the-telephone-network-(dialup) where I put some ideas for this up over the next few days or so.
