Intermittent Communication Failure during download to STAMP board
Hello,
I am having intermittent communications failures while attempting to download the programs to the STAMP board. I've found that if I repeatedly attempt to download the program it will succeed after 4 or 5 tries. Then sometimes it downloads with no problem at all. I've tried running a program with just END in it prior to the download but that has no effect. All programs are terminated with END as well. I've had the problem with programs written by Parallax as well so it doesn't seem to be program related.
Any ideas would be greatly appreciated.
I'm running Windows 7 with more than enough resources.
Thanks!
Thanks!
What's the error message?
Have you gone through the "Connection Troubleshooting" section in the BASIC Stamp help?
And thanks for your help by the way!
Also, the book recommends a 7.5v 1a supply. Any thoughts?
At this point, we forum folks have no idea about your setup. I can only speculate that since you're referencing 7.5V you do not have a BOE and have wired the STAMP to your PC by some other means. The accuracy of forum response is directly proportional to the information supplied.
EDIT: Oops, posted at the same time.
Since I don't know for sure what information is needed with this device and there is a ton of information possible to give I usually wait until prompted. It appears that the voltage can be between 6 and 9 volts but since the manual suggests the 7.5v one and "go figure" the Parallax store has such a device, I'll probably get that one. Thanks again for the assistance.
"Try setting the "Latency Timer" to 1. If you go into the "Control Panel" on your PC and click on the "System" icon and then click on the "Device Manager" and then click on "Ports" and then "Com". You'll see a USB to com, go ahead and click on it and then click on the "Port Setting" tab and then click on the "Advance" button and you'll see the "Latency Timer", change it from 16 to 1. Let me know if this helps?"
So far this appears to have fixed the problem. I'll repost if it rears its ugly head again.
