mrs1 servo desperation
Hi guys,
I'm really stuck here. I'm using the MRS1 with a 3 ping setup (as the stingray) and things work fine. It roams the room and avoids objects. So at first glance it seems ok.
Now I would like to add some servo's. For testing I just use the servo32.spin something script. But whatever I try I can't get the servos to function in the right way. It jitters but thats about it. I tried adding a resistor to the signal wire and swapped arround servo's. Seems that some respond "little" better then others but never do they work fine.
I then thought it could be some noise caused by the powersupply (there is not much more else on the robot) so I took out a breadboard and seperated the signal wires from the power wires. Still the same. I guess that tells me that the noise is on the actual signal wire either caused by the MRS1 or by the servo's.
I tried the servo's on a picaxe and no problems there. Is there anyway I can trouble shoot this without an oscilloscope or do I have to start saving for one?
Thanks a ton!
DutchBot
Thanks a ton!
DutchBot
Can there be a separate power supply for the servos, and just connect the ground? For example, a wallwart for the prop chip, and a bench supply for the servos in testing, and in the final application a small battery pack for the propand BIG battery pack for the servos? If so, do these need filtering?
