Light airplane propeller imbalance
Hello,
I try from a long time to make a device for measuring the imbalance of a light airplane propeller.I think I can do that with a Memsic 2125,( only one vertical axis is needed ), plus a Basic stamp and a LCD display.I would like to know the max imbalanced level ( IPS /inches per sec. ) and in which position of the blade( from 0 to 360°).
I need a light beam sensor taped to the cowl of the plane, and aimed at a reflective patch, on the back of one propeller blade.Like this I can measure rpm and blade position, in order to put small counterweights, to counteract out of balances forces.
Could you help me to design such installation?
Thanks in advance.
Michel
Thanks in advance.
Michel
Much as I like to do things myself, I wouldn't even think about going down this road. I highly suggest you leave this job to the professionals.
Edit: At some point your prop was in perfect balance. How is it now out of balance? If you hit something and damaged the prop, that's further evidence that your prop needs professional maintenance.
And there is so much cowl vibration even on a properly balanced prop that you will have significant background noise on an accelerometer.
That's correct, normally propellers are filed down to the correct weight instead of having to have weights added.
Actually, using an accelerometer is quite adaquate for finding the imbalance. Generally, any noise in the system will cancel itself out if properly filtered and the magnitude of the imbalance will clearly exceed the values of the noise. Using the optical encoder combined with the accelerometer will work just fine... in fact, there are several units on the market already that do exactly that. (That's how the professionals do it on a plane without having to remove the prop.)
Here is an example of one of the professional units we evaluated: http://www.rpxtech.com/rpxweb/Dynavibe.asp
Bill
Yes, you are right, but, I would like to know, in dynamic test,How many grams or milligramms, I need to put on the flange of the propeller and where.
Normally for this task, we put one or two washers under one of the bolts in order to get balancing of the propeller.
I know also that electronic tools does exist , but the price is very high.
Michel
Thanks for your help.
Michel
