GPS time parsing — Parallax Forums
GPS time parsing
baysidecontrolsbaysidecontrols Posts: 2
edited 2011-01-09 09:17 in Propeller 1
Using GPS_IO_mini.spin, I am looking for a method to parse the hours,minutes and seconds from the GPGGA sentence. I can get the time but can not figure out a modification that will allow me to parse out the hours, minutes and seconds separately.
  • JonnyMacJonnyMac Posts: 9,693
    edited 2011-01-09 07:01
    It's pretty easy to create a routine that extracts a decimal value from a string -- here's one idea:
    pub str2dec(pntr, digits) | c
    '' extracts decimal value from string
      result := 0                                                   ' clear result
      repeat digits
        c := byte[pntr++]                                           ' get chracter
        if (c => "0") and (c =< "9")
          result *= 10                                              ' prep for digit
          result += (c - "0")                                       ' convert from ASCII
        else
          quit                                                      ' exit if not digit
    Just pass the starting address of the section you want and the number of digits. For example, in that program to get hours you should be able to do this:
    hrs := str2dec(gps.time, 2)
    It appears that the .time() method returns a pointer so you just have to modify that. For minutes you'd do this:
    mns := str2dec(gps.time+2, 2)
    I've tested the str2dec() method so I know it works, you'll just have to experiment with using it and the GPS object.
  • baysidecontrolsbaysidecontrols Posts: 2
    I knew it would be easy for someone. It worked perfectly the first time. Thanks for the help.
    Roger Hummel
    Bayside Controls, Inc.
