Interfacing The CO Gas Sensor Module (#27931) to an RFID Tag ??
Greetings all,
I'm currently working on a course project that involves interfacing the CO Gas Sensor Module (#27931) to an RFID dry contact tag. I've tried doing that via a relay but no luck.
the question in hand is: do I absolutely need a microcontroller for the interfacing to work properly ?? or would a relay do the job? because in the datasheet it keeps going on about using a MC such as the Basic Stamp.
another thing I'm wondering about is the Heat Switch (HSW) input to the module; what is it exactly? is it ok to just ground it and go from there? because the datasheet also says "Heat switch input from microcontroller, active low"
you'll find datasheet links of both sensor module and tag below.. any help is much appreciated![:D :D](https://forums.parallax.com/resources/emoji/lol.png)
CO Gas Sensor Module (#27931) datasheet:
http://www.antratek.com/pdf/27931_C0_GasSensor_v1.0.pdf
RFID Dry Contact Tag (RFCode R130) technical specs:
http://www.rfcode.com/images/tech_spec_sheets/r130_tech_spec_sheet.pdf
Best regards,
Hamad
Best regards,
Hamad
That leaves my second question: what about the heat switch input (HSW) to the sensor module (active low), is it necessary to use a microcontroller for that or will grounding do the job ??
Also please keep in mind that I didn't post this thread until I went through all related datasheets, searched online, asked the professor and even emailed parallax's support about it. Unfortunately no response till now.
So, everyone else, what about the heat switch input (HSW) to the sensor module (active low), is it necessary to use a microcontroller for that or will grounding do the job ??
For now, I know (according to the sample program) that the HSW input is needed mainly before measurements. Hopefully, that'll work.
Again, I appreciate your help, Franklin and Mike. This post is closed for now I believe.
