Can someone recommend a Sata HD Enclosure?
I can easily find one on Newegg or Tigerdirect but I don't know what is bad or good. Our drive is less than 500 GB and some models come with fans and others don't. I won't be leaving ours on all the time.
I'm looking for something that is most compatible with the fewest problems.
Thank you.
Thank you.
One thing I saw that I didn't know existed was the type that isn't actually an enclosure but works like a docking station. I can see how that could be useful in some situations.
Thank you. I took your advice. I ordered one (in white / silver) and it came today. I did some troubleshooting and make sure when you put it in the case that you push the hard drive back all the way into the connections. I works great except for that problem I had initially.
I think the power supply wire could be thicker but I'm not complaining right now.
Rich H
