Circuit board production companies. Who do you use?
For those of you that use a company to make your circuit boards -
Who do you use and why do you like them?
I have my design just about completed in Diptrace and need to move on to production soon. I am just looking for circuit board production at this point as I will populate my first run myself.
Thanks.
Don
Thanks.
Don
For small production, Gold Phoenix.
Tried PCB Fab Express a couple times, quit when they mixed up my boards with someone else's.
I used their "No Touch" service which was affordable. Everything went okay except that the tin coating on the board was a bit heavy resulting in shorts on a 100 pin tqfp. It wasn't really a problem because I had to solder the chip on anyway.
Chris
Rich H
I use http://www.pcbcart.com/ . they are easy to work with and I have never had a quality issue. One time they identified an error in one of my files and let me know before they made any boards allowing me to correct it without cost.
The best board house for you will depend on several factors, here are a few to consider. Different shops have strengths and weaknesses depending on what you need.
1. your location (shipping cost)
2. The size of the boards you want to make (some shops only have great pricing on small boards or standard sizes)
3. How complex the board shape is (are there interior holes, non-rectangular outline)
4. The material that needs to be used (flexible, FR4, other)
5. Trace Thickness (1oz, 2oz, 3oz...)
6. Speed (how fast do you need them)
7. Do you need a stencil for solder paste ?
8. Quantity needed
You get the idea.
So far I've had one run of 25 boards for about $120USD down without any quality problems, but there were a few first time delays as I had to find out how the Eagle files worked with their production equipment.
In my case shipping is quite cheap.
It had advantages and disadvantages, and it depends on your need.
The only make eurocard size or a panel the size of 4 eurocards.
Holes in your file are tool drill size, not finished.
You can have 1 or 2 layers. For 2 layers you only have one option, double solder resist, top silkscreen, plated holes.
On the other hand for a single board they are cheap, and if you compose you panel of many boards (same or different design), and provide straight cut and clearance they will depanelize it for you, for free. You have not setup fee.
If you use the 10 mils option they are rather fast too.
When I contacted the via e-mail I received a fast answer.
Massimo
Bill
I use Sunstone for everything else. They work with the assembly company I use (Screaming Circuits), so that is why.
I used to use ExpressPCB and had some catastrophic results with traces being open and things shorting to planes. I haven't had any problems with the above two fabrication companies though.
