SMD devices for the audiophile - need advice
LoopyByteloose
Audiophiles put all and everything under a microscope. I have an interesting schematic for an Ultra low noise phono cartridge schematic that I am thinking of constructing. But it seems to me that it might be easier to use SMDs in some of it rather than larger components.
At odds are whether there are audiophile quality resistors and capacitors available in SMDs. I just don't know.
My suggestion, Loopy, is to buy high quality components with very tight tolerances and you should be just fine. The important part is truly understanding the complexities of audio reproduction in your circuit design.
Bill
>>EXAMPLE<<
Absolutely not! As long as they are good quality components, SMDs will make for a very nice and compact design.
Bill
Agreed! BTW... I have some lottery tickets available if anyone wants to buy them... the're last weeks tickets, but I'm selling them for 50% off!!!
http://www.thecableco.com/product.php?id=3494
I especially like the ceramic casing, rather than glass, for better resonance characteristics.
Here is a "review":
http://www.positive-feedback.com/Issue32/fuses.htm
I know of an XMOS based high end USB audio design that will be announced at CES that had struggles through prototyping due to the quality (tolerances) of the components. Most SMD resistors had to be changed to 0.1% to stabilize to the desired results. Some of the power supply parts were also changed to make the voltage rails very tight since the processor is extremely sensitive to voltage variances. In the long run however, this product will have specs that will be new to the high end USB audio market. Using standard tolerance parts would not allow a product like this to be completed.
Actually, I do tend to lean towards the feeling that the endusers are 'Audiophools', but the quality control of ultra low noise, ultra low distortion is a very real issue. From my research on the web, every once in a while an intelligent engineer comes up with a very good design and builds it as a proof of concept of what can be done. (see the JLH Class A solid-state amp) and then others 'massage' it into audiophile tweaks that keep the religion intact.
The main thing I am exploring is whether there is any real need to build a nice 10 watt Class A system with vacuum tubes. I suspect not. At this point, I've pretty much figured out the Power Amp and the Power Supply, but the Pre-amp design is a bit more of challenge as RAII Photo cartridges offer up a signal at micro-volts.
Audio does certainly seem to attract some of the dubious sorts of electronic engineers.
Bill
Nonetheless, that is the point, to move beyond tubes and into this century, completely.
In reflecting upon the past few decades I must say that we have left behind a golden era of audio hi-fi and gotten more and more into visual technologies. In some ways, it is quite ironic. The truth is I really don't have any vinyl disks to listen to and not much of an audio collection. It is the conceptual engineering that appeals to me. There just seems to be some very good components available that don't cost an arm and a leg because no one is producing them anymore.
I'm attaching a short article from EDN that talks about audio coupling capacitors and THD. It compares mainly X7R and X5R ceramics, but the principles are well laid out as they apply to any coupling capacitor.
DJ
There is a difference in the sound of good audio equipment vs. bad audio equipment, but it's been made so that you can take it too far, and fools will still pour their money into it.
What really matters I think is the build of the circuit. Does it have a lot of traces? The more metal, the more noise, and although there are ways to reduce it, it still makes a difference.
Thanks for your very useful input. I had suspected that capacitors have move techonologically forward while the audiophilia are going Mach 1 in reverse. If I can get some good ones, this will make a fun project as it may sort out which is the leading edge and which ain't.
The main idea here isn't to gripe about the high cost of dubious audio, but to share real knowledge about real devices that really don't have to cost an arm and a leg to get it right. One can build a rather complete solid-state stereo system that will perform as well or better than tubes for less money and not have to sweat future purchases of tubes.
http://www.national.com/an/AN/AN-346.pdf
Only benefit I can see is that silver may tarnish making the contact more resistive unlike gold which is inert.
People when given a choice tend to go for the most expensive thinking they are getting the "best" Bose being a prime example
Here in Southern Taiwan we have a sub-tropical climate and a major steel industry, everything corrodes quite quickly. My first computer here begain to rust in two years, whereas my computer in California never showed any corrosion. So I will go with gold connectors in any audio that I build to last. Chrome is a porus plating and requires an undercoat of copper to prevent the base of iron from rusting - certainly a more complex process than a single layer of gold plating.
I don't take issue with items that are functional. It is when people go beyond reasonalble engineering to junk up a design with all and everything exotic and expensive that audio becomes absurd. I doubt I would use pure silver wire for tweeters as some are doing these days when just a larger diameter copper might do the job.
check out Wima capacitors
