Begginner Forum
Would be nice to have a beginner forum where people new to electronics can ask questions. Maybe even some beginner projects could be posted there as well.
Just a quick question from a newbie -
On the Propeller Demo Board there is a bread board with nodes (5 holes long ) I am assuming running parallel to each pin 0 thru to 7, 5v, VDD's and VSS's with two spare lines at the bottom of the breadboard. The board is split in the middle with a channel. Do the nodes continue the circuit to the other side of the channel? Is there a schematic for the nodes?
Regards
(not so Tricky at the moment)
Trick
Regards
Trick
Every set of five "nodes" is connected together. The sets are not connected across the channel. This permits the use of DIP packages on the breadboard.
Silly me I also just found the resources tab with the basics of bread boarding demo.
