Trying to communicate with an LCD0821 rev 2.0
Has anyone tried to use the LCD0821rev 2.0 with a BS2? There isn't any sample code available as far as I could find and I'm having issues trying to communicate. I'm using the three pin connector for what I believe is TTL. Should I be using the four pin connector?? Any help or example/direction to get me started would be greatly appreciated. Thanks,
Can you post the code your using?
here's the link to the LCD0821
