Can ColorPAL measure light intensities like the TSL230R Light to Frequency Chip?
Can the ColorPAL with it's integrated TAOS TSL13T Light-To-Voltage sensor measure light intensities like the Parallax TAOS TSL230R Light-To-Frequency Converter chip?
I am more interested in overall light intensity measurement than color determination. If possible this would be very useful as the ColorPAL has the RGB LEDS integrated along with the sensor.
Many thanks!
Many thanks!
Many thanks for your answer. Two questions please:
1) I noted that the TSL230 has a spectral response of 350-1000nm, while the TSL13T has a spectral response of 320-1050nm. Are these figures the "dynamic range" that you mentioned?
2) I have been working with the Parallax TSL230 (which I believe is the TSL230RP-LF) and have noted that whenever I perform a light reading such as a simple red LED in a black box, that the intensity reading continuously (ie, every 0.10 second) decreases a digit. This occurs when operating the Parallax spin demo code for the TSL230. Do you think it is hardware, software? I have tried many different LEDs and the same result occurs. Any ideas greatly appreciated as this is a consistent problem in trying to obtain stable readings.
In advance, thank you!
2) I don't really know about this one, but here's a guess: If your LED is current-limited using a simple resistor, the resistor could be warming up and slightly increasing in resistance as a consequence, thus reducing the current available for the LED. Try using an LM317L instead of a resistor to regulate the current going to the LED. Also make sure that the TSL230 has a very clean and constant Vdd supply.
I appreciate you taking the time to assist, thank you!
