Run two program in one stamp with one Pin by switch
This my sample program
HIGH 11 ' the problem when this pin in high it just run the main_loop
Main:
IF OUT11 = 1 THEN GOSUB main_loop ' this must wait until switch turn on
IF OUT11 = 0 THEN GOSUB recieve_mode ' i need this run first until switch turn
RETURN
Any help thanks.
Main:
RETURN
Any help thanks.
If the switch is connected to pin 11 then you need to replace the "if Out11=" with "if in11="
Also have you a pull-up resistor on the line to start it with a known value?
i try what you say , but still have that problem , so anyway to make the main_loop run together with recieve_mode , i main it two program run at same time , because i have two bs2 run on this one project so the main_loop it that for say it module and the recieve_mode that recieve byte from the master bs2
Main:
IF in11 = 1 THEN GOSUB main_loop ' this must wait until switch turn on
IF in11 = 0 THEN GOSUB recieve_mode ' i need this run first until switch turn
RETURN
Why are you using High11?
Have you an external switch connected to pin 11?
Main:
IF OUT11 = 0 THEN GOSUB receive_mode ' i need this run first until switch turn
RETURN
Are you want to use an input on a Basic Stamp if this is the case then the command would be
this
Mode VAR IN11
DO
IF Mode = 0 THEN
GOSUB Receive_Mode
ELSE
GOSUB main_Mode
ENDIF
LOOP
Main_Mode:
'Your code
RETURN
Receive_Mode:
'Your code
RETURN
Below is a code routine doing just what your are asking to do in my routine you have to power down the Basic Stamp to change modes but I could have written so I could have done with out turning
Keep in that if you want change modes you are going to have to put this in a DO LOOP
Using OUT11 = 1 and then right after using OUT11 = 0 is not a good habit to get into
Hi Clive i used external switch to connect to Pin 11, like i say i have use two Bs2 to connect together by Pin11 because my project need many I/O so one Bs2 not enough for it so that why i need run two program in one stamp the master stamp with all the sensor and the second with some light servo anh say it module , but say it module it have run in loop mode, i know Bs2 stamp just do one stack a time so the switch may help on this.
Sam_Sam_Sam i try your code but not work , any help thanks.
