Yet another BS2 not identified
Hello everyone,
I recently purchased a "Robotics with the Boe-Bot" Kit (USB), however, right from the start, I am having the seemingly common issue of my Basic Stamp being unidentified(Loopback and Echo both say "Yes", Device Type and Version are blank).
Here are the things I have tried:
Three different usb cords, including the one included with the kit.
The battery pack included with the kit, loaded with two different sets of brand new AA batteries.
Two different brand new 9 Volt batteries.
A 9 Volt wall adapter.
Reinstalling FTDI drivers.
Setting Latency Timer to 1.
Is there any more troubleshooting that I am missing?
Weird thing is, I have gotten the Stamp Editor to identify the Basic Stamp about 5 times, randomly over the past couple of days. I have no idea.
Thanks in advance.
Thanks in advance.
I'd use the usb cable that came with the kit. The installation of the correct driver is critical, and I believe the driver must be loaded before plugging the cable in. A link to the most recent driver is on the Parallax website.
Also, if you've been playing musical usb's, its possible the Editor software is trying use the wrong com port. You can check by going in edit>>preferences>>debug port to make sure its talking to the correct one.
It may also be necessary to use the OS device manager to manually delete any unused usb com drivers and then reinstall the correct FTDI driver before plugging in the cable.
Power is on, light is green.
Only things on the BOE is the stamp, battery pack and usb cord.
I've tried using it on Windows XP(Desktop) and Vista(Laptop), with the same results on both: It's been identified a few times while randomly pressing Refresh, but it doesn't stay identified.
When you say "the driver must be loaded before plugging the cable in", what do you mean exactly? Sorry, I've just never had to mess with any of my drivers before. :P
Thanks guys, I just hope this isn't a hardware issue.
Downloaded the FTDI driver from the Parallax site.
Uninstalled the device through the device manager.
Unplugged the device.
Ran the installer, "USBDriverInstallerV2.04.16".
Plugged the device back in.
Tried the above again, but plugged the device into another port.
Is this what you mean? Because it didn't seem to do anything. :P
Right now I have only one COM port, "USB Serial Port (COM 6)":
Driver Provider: FTDI
Version: 2.4.16.0
Argh, I really hope this isn't a hardware issue.
First, disconnect any circuits that you might have connected to the BOE/STAMP. That would be the IR stuff, servos, etc. You just want the BOE with the STAMP, power, and the USB cable connected to the PC. Preferably, you using a 6-9v 500mA power supply and not batteries. If you don't have a 6-9V power supply, that's ok, but they are very convenient and work well... as long as you pay your electric bill.
1) Open the device manager
2) Power the BOE/STAMP
3) Connect the USB cable
4) You should see a new USB serial port in the device manager
5) Open the PBASIC editor and Run -> Identify (Ctrl-I)
6) Or try running the following code
Nothing.
The device manager still shows the same driver and settings as before.
The symptoms you describe are typically from power problems. If you plugged in a 9-volt wall-wart to the wall and to the BOE properly, that should have worked.
Ok, well I guess at first it was a usb issue, but since it was on so much over the past week, I guess that drained my batteries, so that when I solved the usb issue, it still didn't work because my batteries were dead.
Switched out the batteries, it's working great, I'm already making stuff beep and flash and spin.
Thanks for the help everyone, next time I will remember to keep trying different power sources.
Last night: I have the actual boe-bot structure assembled, with a little demo program that buzzes the piezospeaker, blinks an led, and rolls it forward. Works like a charm, I go to bed.
This morning: I flip on the switch, piezospeaker buzzes, led blinks, servos turn...servos stop, piezospeaker buzzes again, piezospeaker buzzes again, etc.
It gets worse throughout the day, until it does nothing at all, BASIC stamp can't be identified, but since the green power light is still going strong, I try wiring an led up to vdd, and it shines like the north star.
Despite this, I went to the store and bought a brand spanking new pack of batteries, tried them, same deal.
I'm going to try tech support tomorrow, but until then, any thoughts?
Thanks so far.
Buy a Wall Wart power supply for this project.
I wouldn't buy any more of those cheap Chinese battery's.
Measure the current from your source ( batteries , wallwart etc.) You should see no more that 50mA at RUN and few mA at idle..
Do you?
