Find value from longfill — Parallax Forums
bennettdanbennettdan Posts: 614
edited 2010-12-30 14:12 in Propeller 1
Hello,
What I want to know is how to loop through say three longs that i have used the "LONGFILL" instruction to enter the values to see if they match a know value then execute a function if they match.
  • andrewsiandrewsi Posts: 59
    edited 2010-12-29 20:01
    I'd love to try to help, but I'm finding your description very hard to understand. LONGFILL will take a certain value and fill a range of memory with that value repeatedly. What are you trying to compare, and what are you trying to accomplisb?
  • JonnyMacJonnyMac Posts: 9,843
    edited 2010-12-29 23:22
    As Andrew points out, longfill will fill the group of longs with the same value -- longmove copies a set of values from one location to another. You could write a simple compare method like this to see if one set of longs matches another:
    pub lcompare(pntr1, pntr2, len) | count
      count := 0
      repeat len
        if (long[pntr1][count] == long[pntr2][count])
          count += 1
        else
          quit
      return (count == len)
    You have to pass the addresses of the arrays you want to check, as well as the length. If they match, you get true back, otherwise false.
  • AribaAriba Posts: 2,697
    edited 2010-12-30 03:34
    If you define the 3 longs as an array, then you can access them easy.
    VAR
     long longvars[3]
     long ok, i
    PUB TestIt
      longfill(@longvars, 9999, 3)  'fill the 3 longs
      ok := true
      repeat i from 0 to 2
        if longvars[i] <> 9999      'test if value matches
          ok := false
    If you only have a pointer to the 3 longs then use the methode that JonnyMac shows.
    Andy
  • bennettdanbennettdan Posts: 614
    Thanks Andrew, Jon and Andy
    Let me see if I understand you gentlemen right if I have the Pointer name and Length of the long I am looking for then Jon's example will return true it if it is match. If I want to scan each Value in an array of longs then Andy's example will look at each Value not just the name and length. Is this Correct?
