Help with using TV with prop-stick USB.
I found the demo file TV_Text_Demo.spin and i want to know what pin to connect the video input to.
(It is for RCA video right?)
Also, how do you use the VGA one also?
A good driver allows you to change the pins by changing a constant per pin or one constant which defines the base pin. Base means it's the first pin and all other pins follow this one in a row.
however some vary rare computer video cards had a feature that would output TV compatible video from its VGA connector. for those computers only, a cable with VGA connector on one end and s-video on the other will work. that is what is sold on eBay. Check the info on your computers video card, as you will need to activate a software switch to convert its output from standard VGA to TV inside the computer.
===>usb tv tuner
Now to your question. TV is (here) composite video and usually NTSC but most drivers can also be configured for PAL. There is a 3 or 4 pin network of resistors (usually only 3 are actually used) and usually on ports P12-14(P15). It is easy to connect the resistors to the pins. See the Propeller Demo Board schematic on the Parallax Store for the circuit and values.
mauriala: Welcome too. I note you refer to VGA and S-Video - we are talking about composite video here. A composite video input on a TV us usually a Yellow RCA connector. S-video is usually a mini-din8 and VGA is a DB15 using 3 rows of pins.
