Diptrace question for those of you that use it
When designing a board layout, in order to get the traces to lay nice and even with the IC pins, do you change your "snap-to" grid spacing to the same spacing as what the IC pins are?
For instance if I am placing a QFP IC package that has lead spacing of .5mm, would I need to set the snap to grid to .5mm in order to make things line up nicely?
Silly question I know but one I need to ask none the less.
Thanks.
Thanks.
http://alternatezone.com/electronics/files/PCBDesignTutorialRevA.pdf
Massimo
