Propeller counters control
Hello,
I'm trying to learn how the COG counters work to generate a square signal. I got them to work, but the main pb for me now is how can I force the start state of a signal?
I mean if I want a 10KHz signal (for example), I'm able to setup the counters to generate such signal, but how can I ask the propeller to start the signal with a High level each time I trigger my counters?
Regards
Regards
For example, when using the NCO mode you simply preset phsx to e.g. NEGX ($8000_0000) which means that bit 31 (the NCO output) is initially high and frqx accumulation continues from there (by default the counter registers are cleared).
Just for clarification, what do you mean by "trigger my counters"? Normally you set them up and forget about them. Or does it simply mean you "start" them?
I mean starting them
regards
