Circuit suggestion for battery opeeration and solar panel
I would like to have a suggestion for a battery operated board.
I'm thinking of using 4XAA NiMh battery pack and a linear regulator. I would like to add the 6V solar panel as an aid to increase battery life.
Please find attached the cicuit I would like to use. I would appreciate any suggestion.
My assumptions are:
- Components should be hand solderable, SMD is ok.
- A switching regulators offers limited advantage for this type of battery input over linear regulators (for instance lm2594-3.3 requires 4.7 volts minimum, and many buck-boost use a linear stage when in buck mode. Hand solderable buck-boost are difficult to find)
- While open circuit voltage of a solar panel is above 7V the voltage instantly drops with current flowing
- even if with fully charged batteries, and in better than optimal conditions, a less than 200mA current flow from the panle is almost a trickle charge cuurent. Moreover it is a remote opportunity
- no voltage limiting (zener) is needed
- a schottky diode would avoid current reversal in the solar panel, at the cost of a limited voltage drop
Thanks in advance,
Massimo
My assumptions are:
Thanks in advance,
Massimo
