16segment data table.
Just got a Prop Pro develompent board for Xmas and am playing around with it. I am trying to get the sixteen segment displays to work. I found an object on OBEX called (you guessed it) sixteen-segment.spin. Simple mux display driver that works fine EXCEPT there are a LOT of errors in the data table resulting in bad characters.
I have been modifying the data table in a very tideous manner to get the correct segments going but I am facing retirement soon and would like to finish this before then. (lol)
Does anyone have a correct data table for the display on the PPDB? Please save my fingers and come to my rescue!!
Thanks, mike B.
Thanks, mike B.
Look close, on the prop pro board the segments are not in order..
Not trying to insult You, But if this was not allready noted, You will get alien script..
I can't think of any math relationship between ASCII and the segments to make this easier, so with the PPDB schematic for the displays on one computer I am fixing the bit patterns as I go. Looks great when the correct segments are lit..
Thanks, Mike B.
Then promptly cut and respliced the harness into the correct order...sigh...
Here's his: m l k j i h g2 g1 f e d2 d1 c b a2 a1
Yikes. Looks like I will have to edit all 128 bit patterns... Bummer...
Mike B.
If the way folks write the software is different than the way the PPDB is wired makes me wonder why Parallax did that?? In my search for some info on this I thought I read where Chris said all the pins needed to be in order, ie: A1 to P0, A2 to P1 etc. Guess I assumed wrong.
I'm going togo and start over and hook the segments up that way they appear to be in the object.. I'll report back..
Mike B.
I love my PPDB!!
Mike B.
Bottom line is you nailed it right off. Thanks
Mike B.
This stuff is so easy, it's hard.
I Have to admit, "Segment's not in order" does sound somewhat cryptic...
I have found developing a communitive standard with a keyboard is difficult and awkward at best...
Especially when Your day to day Hand Tool's are primitive in nature.(My Hammer is My Keyboard)
Often what I type lack's the necessary Tonal Deflection's to "sound" as friendly as intended,
And that leaves Me wide open to broad interpretations..(not good).
If it can go wrong it will...without mercy.. and Karma is Your only defense...
Let us all endevour to mantain a behavior that is both model and beyond reproach..at all times.
(Hey where is the emoticon with the Halo??? im gonna need one.) :cool:
