Good type of battery for solar cells?
I have looked at a bunch of different chemistry's(Lithium ion, lithium polymer, nickel cadmium, nickel metal hydride, even sealed lead acid). I wonder. I know they say that sealed lead acid types are good for trickle charging, but they are kinda weird... I like lithium polymer's, but i watched a few documentary videos that showed them exploding and leaking toxic gas when over charged. I think if i am careful, lithium polymers will be my best bet? A lot of tutorials also use lithium polymer's to!
I have a GSM project that needs 3.3 V the module that I'm using also has a lipo charging circuit built in so a 6 V solar panel with a diode will give me 5 V which is what the charging circuit needs if you need 5 V at a lipo's then you also need to step up circuit and there are some boards out there to make that easy.
My favorite is still the little 6 V they are very rugged little beast
the general rule of thumb I use on solar powered systems when calculating battery and panel sizes, I like to have 3 to 5 days reserved capacity and I use five hours per day to calculate my charging. I built some solar powered LED lights that the city uses on signs coming into town that have been running for over six years without a single issue.
http://www.sparkfun.com/products/7845
I need to find a small battery and one that is light weight(Sealed lead acid types are pretty hefty)... Right now i am only starting to experiment with solar. If i like it(and i am sure i will), then i will move up to higher powered cells and beefier storage systems. The battery i am thinking of purchasing is this one..
http://www.sparkfun.com/products/341
I will have to lower the voltage a little, but that shouldn't be to hard!!
At the opposite end is Lithium technology that pack the most power per ounce of weight,and don't hold charges as well as lead acid. But they do tend to recharge very quickly, I suspect faster than any other chemistry when handled with the right charger (thus their use in cellular phones and laptop computers is not all about the light weight or length of charge - they tend to do well in a deep cycle of charge and discharge situaition)
Finally you have NiCd or NiMh that are in between, easier to build a charger for than Lithium and also less costly. I've never actually built a Lithium battery charger as they seem to demand rather complex charging (pre-charge trickel, then regular charge, then top off WITH temperature sensing and often with balanced charging.
I guess this is for your Propeller PDA project and single cell 3.7 Volt Lithium flat packs are likely to be a first choice. But it also helps with solar to 'think big'. It is difficult to get a successful solar charger in a small package for DIY - much easier to build a cost-effective big one.
SparkFun's disclaimer "Do not attempt to charge these with anything but a specialized LiPo charger." points out the problems with all Lithium technology - What do I do for a charger and what exactly is going to happen if I make a poor design choice? The powers that be don't really want you to DIY Lithium chargers.
From what I can figure out, nearly all batteries work better and last longer if they are kept above 50% of their rated voltage, so some illusions about how much increased capacity from higher voltage batteries need to be considered. There is a gain, but roughly 50% or less of what most people expect. Sometimes it is much better to have a larger capacity nearest your desired use instead of regulation burning up power resources.
And so.... add this item.
http://www.sparkfun.com/products/726
Here is a LiPo charger that I found for the type of battery that you posted. www.sparkfun.com/products/10217
or search LiPo charger on the Sparkfun.com and will get 16 results for that type of charger.
I just want to try something to get my feet wet a little. I thought that you could charge lithium polymers from any power source as long as you didn't go over the voltage rating and made sure to not charge it with more current than its capacity in mAh's? You would also need some way to shut off the power once the battery was charged, right?
I have 2 solar panels and a 2 solar chargers for the USS Zuni/USGC Tamaora, which is a ship that I am helping to restore. This system can be switched between 12v and 24v to charge lead-acid batteries at 1 amp hour. These chargers cut back in the amps only. You may think, that the voltage will be higher. Yes, that is correct when the amps are low and only when the voltage doesn't on the panels.
I will be using this system for another project on our ship as well. You can see this system on EFX-TEK.com forums under completed projects.
And so, matching up a set of Sparkfun products that they have managed to make work well is an easy way to go.
I have no trouble with building a Lead Acid or NiCad or NiMh charger, but Lithium sees a bigger challenge. For a short period extreme high rates are often employed and thermal sensing is quite important in such context in order to avoid explosive failure. If good information evenually leaks out, fine. But until then, I personally feel it isn't worth the trouble. Buyer beware - commercial chargers sold by battery makers actually may be built to quick charge the battery and NOT to optimize the batteries useful life. After all they are in business to sell MORE batteries, not less. That is certainly true of NiCad and NiMh chargers.
