Using Pressure Switches to fill air cannon chamber
I want to use a prop to control an air cannon. Using a tire inflater to pressurize the air chamber to about 100psi and triggering a solenoid valve to release. I want to use the pressure switch to turn off the inflater after it reaches 100psi.
I found these industrial pressure switches and was wondering if anyone has used them with a prop.
http://www.omega.com/ppt/pptsc.asp?ref=PSW-190&Nav=autc04
As for compression chambers and so forth, I hope you're not planning on using PVC pipe to store compressed air. When it fails, PVC pipe splinters really badly and therefore fails in a very dangerous way.
Was planning on using pvc (hot water tank rated). The youtube videos I have seen have went up to 100 psi but what I want to build is this boom stick out of make magazine and he was maxing his at 60psi.
http://makezine.com/13/boomstick/
From comments from the creator it sounds like he has had some blow out (up) problems also.
Is there a cheaper alternative for doing this?
The B&D air compressor that I have actually has a settable gauge, but the only way to start it going again after reaching the set point
is to flip the switch on and off.
Just because something is rated at 140psi for household plumbing, does not mean that it can take the kinds of shocks they are subjecting it to (cyclic fatigue) and be safe with air pressure.
look at these you can get it fromGrainger
http://www.grainger.com/Grainger/CONDOR-USA-INC-Pressure-Switch-3AFU5?Pid=search
