Using a DAC, Mosfet and an OP-AMP
I was wondering if someone could offer up some advice.
I am running the propeller that outputs to a DAC. The DAC then places a voltage between 0v - 5v into a no-inverting op-amp with a gain of 3. The op-amp then fedds into a Enhancement N-Chan mosfet.
My concern is that I will be wasting the lower bits of the DAC because the mosfet wont turn on till ~ 2.2Volts. I am trying to figure out how to bias the mosfet at 2Volts so that I can use the full spectrum of the DAC. Any advice will be appreciated.
The mosfet is configured as a current controlled device.
I figured the op-amp should be a gain of 3 because the mosfet ranges from 2v to 15v.
Feedback at the moment is a ADC that measures the temperature of the heater.
Is there a way I can offset the voltage using an op-amp. I have tried various methods and cant seem to pull it off. My last attempt was 2 op-amp circuits one was a non inverting gain of 3(mentioned already) that feed into a adder op-amp circuit. Its not proving to be the best approach.
