What Type of encoder is This?
lardom
I let a quadrature encoder gear motor sit in a drawer for a year because I found a stepper easier to learn. I'm ready for it now but I'm asking someone to please help me understand what I'm looking at. I attached pictures. All I can tell is that there are two hall effect sensors.
If you're trying to figure out what the magnetic field looks like, perhaps consider using a magnetic visualization film, ~$3:
http://www.gaussboys.com/ndfeb-magnets/GVF075.html
I wouldn't try covering it with paper and sprinkling iron filings on it because there's a good chance you'd get iron filings all over the motor.
Perhaps if you give more info about what sort of wires it has, maybe somebody can tell you more about what its inputs and outputs probably are.
Out of curiosity I did some searching and found this http://www.hennkwell.com.tw/download/12.HE372E.pdf hope it can help. You might have seen it already.
Ron
http://eprints.usq.edu.au/6168/1/Miller_2008.pdf
The pdf states that the motor produces 12 pulses per motor rev and 624 pulses per output shaft rev.
Rick
