Win7 64-bit com port not resetting ?
Good day.
I"ve searched the forum to find a similar post, but could not find any, so I apologize if a similar post
exists.
I'm running a propeller education kit, using Win7 Pro 64-bit, and have the FTDI driver 2.8.2.0 (7/12/2010)
64-bit presumably. The com port (13) chosen by the system appears to work, but only once, and will not
reset. I have to unplug and re-plug the usb cable to reset the port every time I use it.
The port settings are 9600/8/n/1, no flow control.
Has anyone else seen this behavior for the usb connection ?
Thanks....
Tom C.
exists.
Thanks....
Tom C.
Latency Timer = 8ms
Serial Enumerator = unchecked
Disable Modem Ctrl as Startup = checked
I think only the 1st one mattered. I also noticed the problem was worse when the USB2.0 speed was set to fast (480MBps), better when set to hi (12MBps), and almost gone, but not completely, when disabling USB 2.0 completely. Also, the problem existed for 2 earlier revisions of the FTDI driver. This was on an Ion motherboard.
Jonathan
I finally figured it out when I loaded a program into ram, and a message popped up that
com13 could not be reset, and that 'hotsync manager' would try to reset the port.
I turned off my Palm Hotsync Manager, and the port was free to be used again. No
reset message, I can load as many programs consecutively without having to unplug
the usb cable.
My bluetooth connector for the pc is on usb too, and my keyboard, and mouse.
No wonder it was messing up.
Thanks to everyone.
Good it is working now for you.
I have
two USB harddiscs,
a USB DVD-burner,
a scanner,
a usb-to-parallalport-converter,
a PS/2-keyboard to USB converter,
a wiresless mouse-receiver
and a propeller-chip
all connected via USB to my DELL 1721 Inspiron Notebook running Windows 7 32bit ultmate and can connect to my propeller without any problems.
They are all connected through a 13 port-USB hub from http://www.sednacomputer.com/
I don't think it is a "too much devices on USB-problem". USB is designed for hooking up a lot of device
best regards
Stefan
When I try to connect to it using a USB port from the Prop Tool, it work the first time after connecting with the PC app. After this, the Prop Tool can't find the port.
Besides this board, all I have connected to USB is a Keyboard and Mouse.
Any ideas on how to get around this?
Thank you for the help.
Jim
