I have a problem with my mini Atom Bot board V2 and my basic stamp plugged in
I have a mini atom Bot board V2: http://www.robotshop.com/lynxmotion-mini-atom-bot-board.html
but I don't know what battery I should buy to make it work.
Can someone help me?
According to the data sheet here: http://www.active-robots.com/products/controllr/bot-board/bb2pdf.pdf
VL can operate from a 9V battery while VS (or VL and VS together) can operate from 4.8 to 7.2 volts. Connecting a 6V battery to VL (with the correct jumper setting) should get you started.
Amanda
and find out it can't be plugged . would you now a link to a site with a good battery pack?
thanks
From the look of the board in the diagram, it appears to have a screw terminal block. You should be able to find a 4-cell AA battery pack at any electronics supply store. Parallax also sells them for about $3.00
Amanda
