Propeller and Camera
I have a project in mind, and I'm looking for info on how/if it can be accomplished.
I'd like to have a microcontroller, camera (for still photos), motion sensor, and flash card. When motion is detected, take a picture and record it to the flash card for review on a PC.
Can this be done with the propeller? What components would you need?
Thanks for your help!
The functions 'wake from sleep' and 'shutter trigger' are just on/off.
I think other functions may require a USB interface (but I could get lucky with a serial).
If your cameras have an IR remote this is a lot easier. You just have the Prop control an IR LED and have the Prop mimic the remote. You might want to search the forum for Magic IR or IR Magic to see how to read and send unknown IR signal. There are also several IR remote objects in the OBEX.
I've used the Prop to control my Panasonic PV-GS200 (seven years ago it was a pretty cool camera).
If your camera doesn't have a remote (IR or other) then you'll either need to hack it, to add an external switch (such as a relay), or use a servo to push the button on the camera.
For motion sensing you could use PIR, ultrasonic or some other sensor (it depends on the environment an what you want to detect).
I'll try to find my camera control code. I doubt it will help either of you much since it so specialized (it controls the camera with a RC remote).
