Geo-Caching. Just Getting Started
Hello,
I am looking for some help on a geo-caching project. I have a set of points (much like a scavenger hunt). I have a parallax board with a BASIC stamp 2 chip (as well as the GPS module) and would like to store these points and have my LCD screen show me the distance I am from the points. I am just a little confused as to how I would program this in PBASIC given the length of each coordinate is larger than 65000? Has anyone ever tried something like this in PBASIC or do I need to switch programming languages. Also, do I need to purchase extra memory? 8kb doesnt seem like a lot.
Thanks in Advance for any direction.
Use ATN and HYP to calculate direction and distances between two points.
Rich H
Thanks for the reply. Just a quick question. Would I not need to covnert everything to radians in order to do the math? If so, I would need more than 5 decimals to ensure as good as accuracy as I can get. How would I account for this?
Thanks.
No, the radians are what you get when you do the math (ATN). The resolution of the radians is not great but it works well enough.
Attached is the code that I wrote for this airplane. It navigates to a series of waypoints using a BS2, GPS Module and an auxiliary rudder mounted underneath the fuselage just in front of the tailwheel. It is hard to see in the picture, it is the color of balsa wood.
Once it has passed though all the waypoints it will "orbit" the home waypoint in a figure eight pattern.
As the name of the file indicates, this is a trimmed version. One thing that I see missing is the code that enables/disables the navigation so that it doesn't interfere with RC control.
Rich H
