Propeller and automatic graphs.
I captured temperature with the Propeller and I would like to show it using a graph.
The first option I thought was to use Excel ( copy and paste ) the temperature
data and use the Excel to see the graph.
The second option I would like to use it is without Excel. I want the Propeller to export
the data without a copy and paste. In fact I would like the Propeller to export the data
just after connect it to a PC (something more automatic).
Any idea ?
Thanks Joe
Any idea ?
Thanks Joe
ViewPort would be another option.
For ultimate control and the most work on you part, you could write your own PC program to do what you want.
John Abshier
Or, you could have the data show up directly as a crude graph on a VGA or even a TV using an object like VGA_text or TV_text. http://obex.parallax.com/objects/70/
http://obex.parallax.com/objects/67/ Or you might find other, similar types of "real time" graphical outputs if you poke around the OBEX.
