PropBasic coding and compiling issue — Parallax Forums
bsnutbsnut Posts: 521
edited 2010-12-21 13:46 in Propeller 1
I have some issues that PropBasic is not compiling simple code such as this
if Switch1 = 1 AND Switch = 1 then Count_up
and it gives me this error "INVALID NUMBER OF PARAMETERS You have too few or too many parameters given.
I don't understand why I am getting this error and can someone tell me why this happening.
Below is my code.
DEVICE          P8X32A, XTAL1, PLL16X
XIN             5_000_000
' Constants
' I/O Pins
Light PIN 16 OUTPUT
Switch pin 12 input
Switch1 pin 13 input
Switch2 pin 14 input
' Shared (hub) Variables (Byte, Word, Long)
' Shared (hub) Data (DATA, WDATA, LDATA, FILE)
' TASK Definitions
' Cog Variables (Long only)
northcount var long
' SUB/FUNC Definitions
  PROGRAM Start
Start:
if Switch = 1 then Toggle_onoff
if Switch2 = 1 then Reset_Count
GOTO Start
Toggle_onoff:
if northcount > 4 then Start
TOGGLE Light
PAUSE 1000
GOTO Start
Count_up:
inc northcount
GOTO Start
Reset_Count:
dec northcount
GOTO Start
  END
  • VonSzarvasVonSzarvas Posts: 3,639
    edited 2010-12-21 03:08
    would it solve with this change?
    if Switch = 1 then
        GOTO Toggle_onoff
         if Switch1 = 1 then Count_up
    endif
    edited 2010-12-21 03:11
    ... actually, you might have some other problems with your logic:
    As I can see, the jump to "Toggle_onoff" will always result in sending back to "Start", so you will never get the chance to evaluate Switch1 (either in your original code or in my version).
  • BeanBean Posts: 8,129
    edited 2010-12-21 05:49
    You need to put each condition on a seperate line.
    IF Switch1 = 1 AND
      Switch = 1 THEN Count_up
    Bean
  • JonnyMacJonnyMac Posts: 9,843
    edited 2010-12-21 11:32
    I'm with Max and wonder if this is what you actually meant to do:
    Start
      IF Switch = 1 THEN
        IF Switch1 = 0 THEN
          TOGGLE_ONOFF
        ELSE
          COUNT_UP
        ENDIF
      ENDIF
      IF Switch2 = 1 THEN
        RESET_COUNT
      ENDIF
      GOTO Start
  • bsnutbsnut Posts: 521
    Jon, Bean, and Max the ways that you all shown me will work and I didn't think of trying that at all.
    I am so used to the Basic Stamp why of coding and I was trying to see if it was doable(would compile), that's why I posted the code. I normally do small test code to check things like this and hope I didn't confuse anyone
    Thanks for the help and you all answered my one big question that I had. More questions may come done the pike as I am learning a different way to coded my programs.
