Amount of current the prop power LED draws?
I'm having trouble with depleted car batteries in the morning, and I'm wondering if the prop red LED and a green LED with the same config as the props red power indication LED?
Could these 2 tiny LED's deplete a car battery to not being able to crank the engine over, over a 12 hour period?
You didn't say what else is running. A Propeller can draw more than the LEDs if it's running at high speed. You'll have to look at the various charts in the Propeller Datasheet for exact values for your circumstances. Usually, you can get all the cogs idling for most of the time, tremendously reducing the power consumption of the Propeller itself.
On the high end, the LED will dissipate 120 mW. In a 12 hour time frame even if it runs constant, your power loss is roughly 1.5 watts (that would be max). Hardly enough to drain your battery to a point of non-operation.
-Kevin
My prop is running at 80mhz, is there something I can buy and put inline or around a wire (inductance) that I can see how much current is going through each wire?
I guess I could code it to have most cogs sleep if the key was off? Or should I have it run at a slower speed if the key is off?
Putting the Prop into low power mode when the key is off is a good idea. Switching to the slow internal clock is easy and effective as long as you don't need the speed or clock accuracy. Having the cogs waiting for either a signal or a time in the future most of the time will also markedly reduce the power draw.
I think an LED was keeping a transistor on and that was my issue, I'll know tomorrow. If that's the issue, I'll have to figure out how it is causing such a drain.
Additionally, batteries tend to substantially reduce their output in severe cold. In the Arctic, battery powered devices often are buried 6 feet below the surface just to moderate this effect.
You battery may simply be near the end of its useful life. The 'average' installed automotive 12 V battery is somewhere between 150AH and 300AH, depending on the climate you live in.
I too should have mentioned that I had already ruled that out. I have a battery load tester that I put on the battery and it passed, as well as I also unplugged by prop rig and did not have any issues when it was all unplugged.
I believe I found the issue, I'm just not sure why. My green LED is turning on a FET transistor, just not sure why it is doing that so I will figure that out and get back to this thread.
Thanks for everyones input!
It was definitely the FET/LED combo, using an NPN transistor I have remedied this. Thanks to everyone who replied.
Easiest way to measure the current is place a multimeter in the power path. I presume you know this so there must be a reason you cannot do this.
