The beam gets directed by reflecting it off a small mirror that can be quickly positioned like that, a lot less work and stress than wig-wagging a laser assembly.
Spin a faceted mirror-ball and speed goes way up.
Are you familiar with handheld laser scanners? I noticed that the ones at the local UPS Store have a beam with bright spots at the ends, which suggests a wig-wag type of scan. But one would think, in that case, that they'd make an audible "buzzing" sound, which they do not.
Thanks. I was curious. That means it would be difficult to use a laser to display a pattern. I'm guessing it would make more sense to shine a light through an LCD that has a computer generated image onto a surface through a lens. (Yeah, I know I'm going off on a tangent but I feel pretty normal on this forum!)
Some (most I have seen) hand held scanners use a linear imaging chip to read the bar code. No moving parts and no laser. Bar code is illuminated by a row of leds.
Alot of barcode verification systems that i've seen use a mirror mounted to a swivel that uses a magnetic coil to swivel the mirror back and forth, much like the way a dvd or cd player focuses its lens in front of the laser diode. most of the commercial units ive seen are made by SICK.
http://en.wikipedia.org/wiki/Mirror_galvanometer
examples abound on youtube
