Turn the robot for 180 degree — Parallax Forums
heavy-freelancerheavy-freelancer Posts: 23
edited 2010-12-20 02:13 in Robotics
Hey,
I want to turn my Boe-Bot for 180 degree so if he was going ahead he will turn left and continue moving.
My problem here is I can't control the angle of rotation of my robot.
This is my code :
myVar VAR Word
Begin:
DEBUG "Ahead",CR
FOR myVar = 0 TO 500
PULSOUT 13,850
PULSOUT 12,650
PAUSE 1
NEXT
DEBUG "Return",CR
FOR myVar = 0 TO 500 ' The problem is here my friends (500)
PULSOUT 13,650
PULSOUT 12,650
PAUSE 1
NEXT
GOTO Begin
In this case the robot rotate for anonymous degree.
What do you suggest for this problem.
    edited 2010-12-19 13:34
    As to the turn you will need to figure out the loop count (myVar) that turns the robot 180 degrees.
    The boe-bot's servos are not precision devices and each one is a bit different so there is no "right" value to put in.
    Also the pause in your loop should be 20. There should be 20ms between pulses.
  • hover1hover1 Posts: 1,929
    edited 2010-12-19 13:40
    Your "Pause 1" should be "Pause 20". That is the minimum to keep the servo in place. They have to be refreshed at 50khz. 50hz. (Thanks Rich)
    Jim
    edited 2010-12-19 14:17
    Additionally, you need a "pause 20" after your servo pulsouts, instead of your "pause 1". Servos need to be updated 50 times per second.
    Anybody else care to chime in here? :)
    Captain Obvious
  • ajwardajward Posts: 1,130
    edited 2010-12-19 22:49
    Hey,
    This is my code :
    myVar VAR Word
    Begin:
    DEBUG "Ahead",CR
    PULSOUT 13,850
    PULSOUT 12,650
    PAUSE 1
    NEXT
    DEBUG "Return",CR
    PULSOUT 13,650
    PULSOUT 12,650
    PAUSE 1
    NEXT
    GOTO Begin
    A couple of things, if I may...
    Your "PAUSE 1" needs to be "PAUSE 20 for the servos to operate correctly.
    Then... to execute a turn, the value of 500 seems =awfully= high. While no two 'bots work exactly the same, I've found a value of ~22 works for a two wheel 90 degree turn and ~43 works for a 180 degree turn. To pivot with one wheel stationary, ie PULSOUT x, 750, just double those numbers.
    HTH,
    Amanda
  • W9GFOW9GFO Posts: 4,010
    hover1 wrote: »
    Wow! That there's some fancy servos that need to be refreshed fifty thousand times a second! :)
    Rich H
