Rechargeable batteries — Parallax Forums
heavy-freelancerheavy-freelancer Posts: 23
edited 2010-12-19 09:28 in Robotics
Hey,
I'm using Rechargeable batteries with my Boe-Bot and I found this in the manual :
Avoid rechargeable batteries because ther are 1.2 V instead of 1.5 V.
Is this going to cause problems or what.
Thanks.
    edited 2010-12-19 08:44
    With four 1.5V batteries, you have 6 volts and with four 1.2V batteries you have 4.8V.
    The servo motors that drive your wheels run well at 6 volts and tend to suffer at 4.8 V. Also, the BasicStamp is a 5 volt device though it may operate at 4.8 volts.
    Bean managed to locate a 5 battery holder to allow one to adapt the Boe-bot to five 1.2V cells, but I am uncertain if it is still available.
    In general, low voltage doesn't cause permanent harm - it just doesn't work right.
    There are other ways around the problem. A boost regular could be inserted to provide a steady 6 volts to the servos, then the on board regulator would bring the voltage back down to 5 volts.
    But it needs to provide enough power to the motor. So the available Amps have to be substantial as well, at least 1 amp and maybe more.
    edited 2010-12-19 09:02
    You can add a fifth rechargeable to your Boe-Bot using the Boe-Boost Module, which brings the voltage back to 6V.
    edited 2010-12-19 09:04
    It's very easy to buy a battery holder for a single AA cell and wire it in series with the existing 4 cell battery holder. RadioShack has the single cell battery holders. 5 x 1.2V = 6V.
    I mounted my extra battery holder on the BoeBot's deck above the pivot wheel using some silicone adhesive, but double sided foam tape works fine.
  • John AbshierJohn Abshier Posts: 1,116
    Jameco has 1.6 volt rechargable batteries.
    http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_2115848_-1
    John Abshier
