does any one know
does anyone know a cheap way of measuring flow. In a copper line or pex line for my boiler project.
i have calculated btu's for my storage tank. I would also like to for my boiler but i need flow.
A magflow tube would be too much $. The flow rate is too low for a orifice plate and differential pressure transmitter.
Also, you might want to add some details - what is the fluid? Is it a mixture of air and fluid or just fluid? Is it hot? What is the approximate flow rate range?
the fluid is water
the tempature is 100 to 200 deg f
no air
the flow rate is 0 to 5 gpm
the cirulator is a tayco 007
i posted here for the contest: 30% community participation: Entrants are expected to help others and contribute code on the forums or Object Exchange and use community resources. The final code should have been created by building on community code by adding unique capabilities.
unique capabilities is what i was looking for. I just do not know how to make it aforadble for others.
You can do a quick google search to find more information. You can also fine this stuff in 101 college physics text.
For contest purposes, is it necessary to worry about making it affordable for others? What are you yourself using now to measure flow?
Hope this helps.
Shawn
