using prop plug for another chip
i dont know if i killed it but i tried and failed getting prop recognized. no eeprom or crystal , pretty simple circuit not sure so am ordering another prop, im feeling not so suped up, ill order the regs, caps & crystal new prop and should be good!
I tried using the prop plug to program a picaxe but that IDE wont list /recognise the prop usb-serial like the propeller does.
Its probably that i have been holding my mouth the wrong way, ill try things again in the morning
if im going to order i may as well make it hurt and buy a USB Prop, perhaps.:nerd:
Then check to see is the plug is reversed.
Since the Prop Proto Board as 3 configurations, becareful to determine which is compatible.
I have ordered a new prop(and usb prop) so i will be careful. I cant get this working, perhaps the chip is fried , perhaps not but ill soon know.
I've certainly had my share of sudden death events due to reversed polarity. It always is a jolt to the pocket book, but now I try to pause and verify wiring - especially the power supply - before I power up.
And yet, the Prop Plug is merely a generic USB to RS232 serial adapter - so there really isn't any reason it cannot be used in other contexts and with other micros.
@Loopy, I dont *think i reversed polarity. I will figure it out and post.
