FERRIC CHLORIDE RESISTIVE INK help?
Hello All:
***PCB lay-out****
I have goggled my fingers off. I have watched way to many You Tube videos.
I have seen some really nice boards made with ink-jet printers, Not laser-jet (toner)
But I can't find a source for the ink used in the projects.
I can't believe that its soy based ink that their using.
Any info or help would be great!
Thanks in advance for any help
***PCB lay-out****
Ferric Chloride is one of many acids that are used as a copper etching solution. And what you need is an 'acid resistant ink'. The biggest body of knowledge on this topic is from the art world, where etching on copper has hundreds of years of tradition. You can find a lot of different formulas there for coatings that will prevent the ferric chloride from reaching the copper.
But the short and pragmatic answer is to run some tests. Permanent magic markers seem to do fine, and so does laser printer toner when transferred via and iron on process. In other words, a lot of things will work - but not water soluble ink.
Diluted oil based or latex house paint might do as well. And a spray on polymer coating, such as 'Armourall' might also do fine. Even traditional car wax or floor wax.
Did a google search came up with this http://techref.massmind.org/techref/pcb/etch/directinkjetresist.htm I didn't read the whole page but I did see a reference to a specific ink hope it helps. I am playing with the Toner Transfer Method now.
Ron
Since the boards with their coating only cost me about $2USD and the chemical developer is cheap. I feel that the results are much better. And if I get a bad image transfer, I can scrub the board with iron wool, recoat it with a spray that does the same thing and start over.
RonP:
Thanks for the link. Its was the specific type of ink that I was looking for.
Thanks Again.
