RFID Read/Write Trouble
I just purchased the 28440 RFID read/write module and several different compatible RFID tags. I am using a BS2px24. I used the demo code below. It doesn't detect my tags and display thier number on the debug terminal. I am confident it is wired correctly. Any help would be greatly appreciated.
' File...... rfid_rw_test.bs2
' Purpose... System-level test code for the Parallax RFID Read/Write Module
' Author.... Joe Grand, Grand Idea Studio, Inc. [www.grandideastudio.com]
' E-mail.... support@parallax.com
' Updated... 15 Dec 2009
' {$STAMP BS2px}
' {$PBASIC 2.5}
[ Program Description ]
' This program performs a system-level test of the Parallax RFID Read/
' Write Module by:
' 1) Reading tag's unique ID
' 2) Writing and verifying a block of data to the tag
[ I/O Definitions ]
RFID_TX PIN 0 ' Connects to RFID R/W Module SIN
RFID_RX PIN 1 ' Connects to RFID R/W Module SOUT
[ Constants ]
'#SELECT $STAMP
'#CASE BS2, BS2E, BS2PE
' T9600 CON 84
'#CASE BS2SX, BS2P
T9600 CON 240
'#ENDSELECT
Baud CON T9600
' RFID R/W Module Commands
' Number of bytes returned in ()
RFID_Read CON $01 ' Read data from specified address, valid locations 1 to 33 (5)
RFID_Write CON $02 ' Write data to specified address, valid locations 3 to 31 (1)
RFID_Login CON $03 ' Login to tag with password (1)
RFID_SetPass CON $04 ' Change tag's password from old to new (1)
RFID_Protect CON $05 ' Enable/disable password protection (1)
RFID_Reset CON $06 ' Reset tag (1)
RFID_ReadLegacy CON $0F ' Read unique ID from EM4102 read-only tag (for backwards compatibility with Parallax RFID Card Reader, #28140 and #28340) (12)
' Memory map/address locations for EM4x50 tag
' Each address holds/returns a 32-bit (4 byte) value
ADDR_Password CON 0 ' Password (not readable)
ADDR_Protect CON 1 ' Protection Word
ADDR_Control CON 2 ' Control Word
' ADDR 3-31 are User EEPROM area
ADDR_Serial CON 32 ' Device Serial Number
ADDR_DeviceID CON 33 ' Device Identification
' Status/error return codes
ERR_OK CON $01 ' No errors
ERR_LIW CON $02 ' Did not find a listen window
ERR_NAK CON $03 ' Received a NAK, could be invalid command
ERR_NAK_OLDPW CON $04 ' Received a NAK sending old password (RFID_SetPass), could be incorrect password
ERR_NAK_NEWPW CON $05 ' Received a NAK sending new password (RFID_SetPass)
ERR_LIW_NEWPW CON $06 ' Did not find a listen window after sending old password (RFID_SetPass)
ERR_PARITY CON $07 ' Parity error when reading data
[ Variables ]
buf VAR Byte(12) ' data buffer
idx VAR Byte ' index
idy VAR Byte
[ EEPROM Data ]
[ Initialization ]
Initialize:
PAUSE 250 ' let DEBUG open
DEBUG CLS ' clear the screen
DEBUG "Parallax RFID Read/Write Module Test Application", CR,
", CR, CR
[ Program Code ]
Main:
DEBUG "Reading tag's unique serial number..."
Read_Tag:
SEROUT RFID_TX, Baud, ["!RW", RFID_Read, ADDR_Serial] ' Read tag's serial number
SERIN RFID_RX, Baud, [STR buf\5] ' Get status byte and data bytes
IF buf(0) <> ERR_OK THEN Read_Tag ' If we get an error, keep trying until the read is successful
FOR idx = 1 TO 4 ' Print data
DEBUG HEX2 buf(idx)
NEXT
DEBUG CR
DEBUG "Writing and verifying data to tag..."
Write_Tag:
SEROUT RFID_TX, Baud, ["!RW", RFID_Write, 3, $FE, $ED, $BE, $EF] ' Write $FEEDBEEF into address 4 (user EEPROM area)
SERIN RFID_RX, Baud, [buf(0)] ' Wait for status byte
IF buf(0) <> ERR_OK THEN Write_Tag ' If we get an error, keep trying until the write is successful
DEBUG "Success!", CR
DEBUG "End of test.", CR
END
[ End of File ]
' {$STAMP BS2px}
' {$PBASIC 2.5}
' Write Module by:
[ I/O Definitions ]
[ Constants ]
'#SELECT $STAMP
' T9600 CON 84
'#CASE BS2SX, BS2P
T9600 CON 240
'#ENDSELECT
Baud CON T9600
[ Variables ]
idy VAR Byte
[ EEPROM Data ]
[ Initialization ]
Initialize:
", CR, CR
[ Program Code ]
Main:
Read_Tag:
DEBUG HEX2 buf(idx)
NEXT
DEBUG CR
Write_Tag:
END
[ End of File ]
' {$STAMP BS2px}
' {$PBASIC 2.5}
' Write Module by:
[ I/O Definitions ]
[ Constants ]
Baud CON 396
[ Variables ]
idy VAR Byte
[ EEPROM Data ]
[ Initialization ]
Initialize:
", CR, CR
[ Program Code ]
Main:
Read_Tag:
DEBUG HEX2 buf(idx)
NEXT
DEBUG CR
Write_Tag:
END
[ End of File ]
' File...... rfid_rw_demo.bs2
' Purpose... Demonstration code for the Parallax RFID Read/Write Module
' {$STAMP BS2pe}
' {$PBASIC 2.5}
' This program demonstrates the capabilities of the Parallax RFID Read/
' Write Module.
' Compatible with EM Microelectronic EM4x50 1kbit R/W 125kHz tags.
' These tags can be used in a number of ways:
' 1) Read-only by reading the tag's unique, non-changing serial number
' 2) Read/write up to 116 bytes of user data (publicly accessible)
' 3) Read/write up to 116 bytes of user data (password protected)
[ I/O Definitions ]
[ Constants ]
#SELECT $STAMP
T9600 CON 84
#CASE BS2SX, BS2P
T9600 CON 240
#ENDSELECT
Baud CON T9600
ERR_LIW_NEWPW CON $06 ' Did not find a listen window after setting new password (RFID_SetPass)
[ Variables ]
idy VAR Byte
[ EEPROM Data ]
[ Initialization ]
Initialize:
DEBUG "Parallax RFID Read/Write Module Demo Application", CR,
", CR, CR
[ Program Code ]
Main:
' Code blocks can be commented/uncommented/rearranged to
' experiment with the available features and operations of the
' Parallax RFID Read/Write Module
' DEBUG "Reading tag's unique serial number..."
' Read_Tag:
' SEROUT RFID_TX, Baud, ["!RW", RFID_Read, ADDR_Serial] ' Read tag's serial number
' SERIN RFID_RX, Baud, [STR buf\5] ' Get status byte and data bytes
' IF buf(0) <> ERR_OK THEN Read_Tag ' If we get an error, keep trying until the read is successful
' FOR idx = 1 TO 4 ' Print data
' DEBUG HEX2 buf(idx)
' NEXT
' DEBUG CR
DEBUG "Reading Legacy tag's unique serial number..." ' Read unique ID from EM4102 read-only tag
Read_Legacy:
SEROUT RFID_TX, Baud, ["!RW", RFID_ReadLegacy]
SERIN RFID_RX, Baud, [STR buf\12] ' Get header and data
IF buf(0) <> $0A THEN Read_Legacy ' If we don't receive the correct header, keep trying until we do
FOR idx = 1 TO 10 ' Display the data (ignore final \r byte sent by the reader)
DEBUG buf(idx)
NEXT
DEBUG CR
Write_Tag:
' SEROUT RFID_TX, Baud, ["!RW", RFID_Write, 3, $FE, $ED, $BE, $EF] ' Write $FEEDBEEF into address 3 (user EEPROM area)
SEROUT RFID_TX, Baud, ["!RW", RFID_Write, 3, $FF, $EE, $BB, $EE]
DEBUG "Done!", CR
DEBUG "Reading tag's entire memory contents:", CR
FOR idy = 1 TO 33
Read_Tag2:
SEROUT RFID_TX, Baud, ["!RW", RFID_Read, idy] ' Read data from address location "idy"
IF buf(0) <> ERR_OK THEN Read_Tag2 ' If we get an error, keep trying until the read is successful
DEBUG DEC2 idy, ": "
DEBUG HEX2 buf(idx)
NEXT
DEBUG CR ' Repeat for address locations 1 to 33
NEXT
' Login is only required to take advantage of the password protection features
' e.g., set the tag's password, lock/unlock the tag, or read/write the tag (if tag is locked)
DEBUG "Logging into the tag..."
Login:
SEROUT RFID_TX, Baud, ["!RW", RFID_Login, REP $00\4] ' Login to tag with default password of $00000000
IF buf(0) <> ERR_OK THEN Login ' If we get an error, keep trying until login is successful
DEBUG "Done!", CR
DEBUG "Changing tag's password..."
Set_Pass:
SEROUT RFID_TX, Baud, ["!RW", RFID_SetPass, REP $00\4, REP $00\4] ' Change password from old ($00000000) to new ($00000000)
IF buf(0) <> ERR_OK THEN Set_Pass ' If we get an error, keep trying until the password change is successful
DEBUG "Done!", CR
DEBUG "Locking tag..."
Lock_Tag:
SEROUT RFID_TX, Baud, ["!RW", RFID_Protect, 1] ' Enable read/write password protection of the entire tag
IF buf(0) <> ERR_OK THEN Lock_Tag ' If we get an error, keep trying until the function is successful
DEBUG "Done!", CR
DEBUG "Unlocking tag..."
Unlock_Tag:
SEROUT RFID_TX, Baud, ["!RW", RFID_Protect, 0] ' Disable read/write password protection of the entire tag
IF buf(0) <> ERR_OK THEN Unlock_Tag ' If we get an error, keep trying until the function is successful
DEBUG "Done!", CR
DEBUG "Resetting the tag..."
Reset_Tag:
SEROUT RFID_TX, Baud, ["!RW", RFID_Reset] ' Log out and reset the tag (will require a re-login if trying to access a locked tag after this point)
IF buf(0) <> ERR_OK THEN Reset_Tag ' If we get an error, keep trying until the function is successful
DEBUG "Done!", CR
DEBUG "
", CR
PAUSE 1000
GOTO Main ' Do it all over again!
END
[ End of File ]
