High-precision reciprocal — Parallax Forums
Lord SteveLord Steve Posts: 206
edited 2010-12-18 13:24 in Propeller 1
Could anyone provide PASM code to calculate 2^32 divided by x?
  • mparkmpark Posts: 1,306
    edited 2010-12-16 23:05
    Check out post #13 in this thread: http://forums.parallax.com/showthread.php?123663-What-are-the-standard-clkfreq-values-above-80MHz
    It's Spin, not PASM, but the translation should be straightforward.
  • Lord SteveLord Steve Posts: 206
    edited 2010-12-17 06:55
    PERFECT! Thanks, mpark!
    edited 2010-12-17 11:23
    Here is that algorithm in both spin and pasm.
    Michael, you had asked in that other thread how Kye and I came up with the algorithms. In my case I needed it for the PBASIC on the Stamp, where with 16 bits words it is even more critical. I consider it a fundamental integer algorithm, right up there with multiplication and division. From basic principles, after you do a division, there is a quotient and a remainder. The remainder then is what is to the right of the radix point. This algorithm then calculates the binary fraction to whatever number of binary digits is required. It is just like ordinary long division. At each step it asks if the numerator is greater than the denominator. If no, it inserts a zero into the lsb, if yes, it inserts a 1 and subtracts to get a new numerator. Then it doubles the numerator and repeats.
    In the Prop, this is how a program calculates from a desired frequency in Hertz to the angular frequency required by frqx. But it is also often the best way to handle any integer calculation involving fractions. On the Stamp with 16 bits it is more important than on the Prop with 32 bits, but it is still important for highest levels of precision. The main caveat on the Prop is to watch out for the sign bit.
    spin:
    PRI binRatio(y, x, bits) : f
        repeat bits
            y <<= 1
            f <<= 1
            if y => x    '
                y -= x
                f++
     calculates y/x * 2^bits
     enter with {y < x,    x < 2^30,    x <= 2^30,    bits =< 32}
     exit:  f / 2^bits is the closest binary denominated appoximation less than y/x
     caveat:  take care for the sign bit (see entry conditions)
    pasm:
    ' enter with a and b: a < b, a < 2^30, b <= 2^30
    ' exit with f: f/2^32 =~ a/b  (enter with nbits := 32)
    ' if different number of bits, then f: f/(2^n) = a/b
    ratioxybits            ' enter here with a, b and n
           mov f,#0    ' frequency parameter
    :loop
           shl a,#1              ' double the value of a
           shl f,#1               ' double the estimate of f, appoximation f/(2^n) =~ a/b
           cmpsub a,b    wc, wr       ' if a>=b then a:=a-b, carry:=1, else a unchanged, carry:=0
           addx f,#0             ' add carry to f
           djnz n,#:loop    '  all bits
    ratioxybits_ret      ret
  • lonesocklonesock Posts: 917
    edited 2010-12-17 11:53
    (Quick note, Tracy: you could speed up the PASM version a bit by using "rcl f, #1" after the cmpsub, instead of a shl and addx. And, of course, if N = 32 then there is no need to zero f at the beginning.)
    sorry, back to your regularly scheduled programming [8^)
    Jonathan
    edited 2010-12-17 14:01
    Thanks for the additional info, Tracy!
    edited 2010-12-17 14:15
    Good tip Jonathan. Would this work? The carry needs to be zero going in, and
    and wc on the initial mov should do that I think.
    ' exit with f: f/2^32 =~ a/b  (when entered with n = 32, number of bits)
           mov f,#0  wc  ' frequency parameter
    :loop
           rcl f,#1               ' double the estimate of f, approximation f/(2^n) =~ a/b
    ratioxybits_ret      ret
    edited 2010-12-17 15:18
    Just move the rcl to right after the cmpsub, that way the C flag is always set right before it is "rotated" into the f flag.
    Jonathan
    edited 2010-12-17 16:47
    I see now it should be in that position after the cmpsub anyway. Otherwise the final bit will always be zero.
    :loop
              rcl f,#1               ' next bit & double estimate of f, approximation f/(2^n) =~ a/b
    ratioxybits_ret          ret
    The indentation of the spin version above was off -- I went back up and corrected it. The f++ is inside the IF ...
    Someone asked me a couple of questions in PM, puzzled by 1) how 2^32 divided by a number could be considered a reciprocal and 2) so what if it gives a binary fraction, how do you get a decimal fraction (for display)?
    Say you have 1 / 7531 which is your reciprocal. The algorithm kicks out 32 binary digits:
    result = %00000000000010001011001111000001
    And that value is stored as an integer in a long. The binary radix is implied at the left end. The decimal value of that integer is 570305. What this means is that the original number 1/7531 is now approximated by a number with a much larger denominator, 2^32. Due to the fact that the denominator is large, the approximation is good. ("good" can be easily quantified) You can check for yourself that 570305 / 4_294_967_296 is very close to 1 / 7531
    To transform that to a decimal fraction, use the Prop ** operator.
    decimalResult := result ** 100_000_000
    That gives decimalResult = 13278. What that has done is to renormalize the denominator from 2^32, to 10^8.
    Now the approximation is 1 / 7531 = 13278 / 100_000_000.
    To print that, place the decimal point 8 positons to the left: 1 / 7531 = 0.00013278.
    I hope that might a help to other spinners.
