Help reading a nokia 3310 datasheet cant follow the basics!
Hi, I have just begun looking into some kind of graphics output. First looked at 4DSystems µOLED-128-GMD1 and their datasheets were perfectly readable even for a novice with the qualification i needed help with one of the image commands answered here->
http://forums.parallax.com/showthread.php?127890-beginner-graphics-...%B5OLED-128-GMD1-Object-Image-method-help-needed&highlight=mickal
However those displays start at around $29 and models all the way to ,well a lot. So I bought a nokia 3310 LCD cheap which is less advanced but harder to use.
I can drive it courtesy of code I saw elsewhere(arduino and a basic program picaxe) BUT this datasheet _>
http://www.sparkfun.com/datasheets/LCD/Monochrome/Nokia5110.pdf is above my pay grade. From reading example code (i am sure there will be both basic stamp and prop, sx code when i look).. it sends 5 bytes for each character you wish to display ...see below. The code i have read sends each bit with a pulse of 10us, so 40 pulses for 'A' or 'B' etc.
My question is..... is it possible for me to work out these 5 byte values from the datasheet or do you suggest that I be content that it has all been done for me ?
thanks for your patience.
,{0x7e, 0x11, 0x11, 0x11, 0x7e} // 41 A
,{0x7f, 0x49, 0x49, 0x49, 0x36} // 42 B
,{0x3e, 0x41, 0x41, 0x41, 0x22} // 43 C
,{0x7f, 0x41, 0x41, 0x22, 0x1c} // 44 D
,{0x7f, 0x49, 0x49, 0x49, 0x41} // 45 E
,{0x7f, 0x09, 0x09, 0x09, 0x01} // 46 F
,{0x3e, 0x41, 0x49, 0x49, 0x7a} // 47 G
,{0x7f, 0x08, 0x08, 0x08, 0x7f} // 48 H
,{0x00, 0x41, 0x7f, 0x41, 0x00} // 49 I
My code on the thread below has a specific writeup of all the various modes that can be set on this lcd. It also is setup to run on 3.3v using the prop. (which took a few days of trial and error) This lcd requires the engineer to program the voltage the lcd operates at, into the lcd. Most modern lcd's don't require this. (this thing even has temperature adjustments...)
You're in luck, because I have already made a driver for the pcd8544 chip that is in that and many other nokia lcd's.
Here is the thread.
http://forums.parallax.com/showthread.php?124487-EtPhoneHome-v1.0-A-Nokia-6150%28like%29-pcb-redone-with-two-propellers.-PCD8544-l
If you need help hacking my code into useful code for you, send me a PM or reply here.
