BoeBot using IR sensors
I'm having problems writing a program for my boebot. It has to get himself out of a mase. Can someone please help me? I was planning to use the right turn rule.
thanks in advance :-)
Be sure that the IR sensors are seeing the walls. Color and contrasts are important. The wrong color can make the IR blind.
Build your IR sensors on little pieces of perf board rather than using loose parts. Loose parts are more buggy and make everything harder.
If you want help with software code, it would help to post what you have already done.
