Did I fry my Gadget Gangster platform?
For the upcoming Student LED challenge, I have made a large countdown display using 14-segment LED displays. There are 8 characters in total, and they are controlled by 2 shift registers. However, after wiring them up, the program I wrote ran for about 30 seconds then stopped, now the Propeller tool can't see a Propeller chip. The regulators, EEPROM, and Prop chip were very hot. The shift registers should have sank enough current, as these are low power displays, but is it possible the Prop died from being overloaded? The prop plug still works, and the lights on the board still power on.
You are quite the seasoned forum person, and I'm sure you know that you really need to post a schematic and code to have it looked over.
Your description could mean any of a dozen things went wrong.
Let's look at the docs and lend a hand.
Jim
Luckily the chips are in sockets so if the Prop is toast you can easily swap it out.
Robert
That is the first thing I thought, but the Propeller is pretty tolerant of output to 5V devices rather than input.
@Micro
Grounds tied together?
Jim
Sorry, bad parallel.
Jim
A friend of mine at work,(not in the elc. field) Asked me for a couple of fuses. I gave him a box of 10. He returned about 30 minutes later and asked me if I had another box of fuses. I asked him what happened to the first box I gave him? He replied that they were all bad, since every fuse he put in blew every time he tried to run the small pump he was working on.
