how to use tokenizer.dll in VB6???
anyone know how to properly declare the function in tokenizer.dll in VB?
e.g how to do wite the Declare statement after that you have referred to the tokenizer.dll?
I just get the "can not find entry point to" error...
grateful for any help
/Anders
/Anders
I have had limited success with this procedure. In a declaration module, I have added the following code:
Type pbTModuleRecType ' TModuleRec record type
Suceeded As Long
Error As Long
DebugFlag As Byte
TargetModule(2) As Byte
TargetStart As Long
ProjectFiles(6) As Long
ProjectFilesStart(6) As Long
Port As Long
PortStart As Long
LanguageVersion As Long
LanguageStart As Long
SourceSize As Long
ErrorStart As Long
ErrorLength As Long
EEPROM(2047) As Byte
EEPROMFlags(2047) As Byte
VarCounts(3) As Byte
PacketCount As Byte
PacketBuffer(2303) As Byte
End Type
Type pbSrcTokReference ' SrcTokReference record type
pbtSrcStart As Integer
pbtTokStart As Integer
End Type
Global Sourcebuffer() As Byte ' Source buffer dynamic array declaration
Global TModuleRec As pbTModuleRecType ' TModuleRec declaration
Global TSrcTokReference(2337) As pbSrcTokReference ' SrcTokReference array declaration
Public Declare Function TestRecAlignment Lib "tokenizer.dll" (ByRef TMR As pbTModuleRecType) As Boolean
Public Declare Function Version Lib "tokenizer.dll" () As Integer
Public Declare Function Compile Lib "tokenizer.dll" (ByRef TMRec As pbTModuleRecType, ByRef SBuffer As Byte, _
DirectivesOnly As Boolean, ParseStampDirective As Boolean, STRef As pbSrcTokReference) As Boolean
Note that I used Long data type (4 bytes) in place of the "Char" data they list in the documentation in the TModuleRec record type, since the data is a 4-byte long pointer to a memory location (not a character string). Also, the function declaration for the Compile declaration must include the SrcTokReference type, it is not optional and will not accept NULL when calling the function (contrary to the documentation example).
Next, in my executable, I have tried either the command:
pbTest = TestRecAlignment(TModuleRec)
or, separately, the command:
pbCompile = Compile(TModuleRec, Sourcebuffer(0), False, True, TSrcTokReference(0))
(after filling the Sourcebuffer array with a BS2 command file). I think the TestRecAlignment function is working properly, the result of the function call is True and all the numeric values seem to fill in where they are supposed to. However, I have not been able to get sensible results from the character string pointers. When I look at the indicated memory location, all I get back are "??" strings. When using the Compile function, I also get a True result (as well as True in the Succeeded field), but the PacketCount is 0 and the packet buffer is empty! In other words, I can execute the code without getting any errors but it does not seem to actually compile anything.
Hope this helps and please let me know if you get any farther.
cheers,
Jon
Join Date
03-07-2006
Last Activity
Today 03:16 PM
One Post
You have really been saving it.
P.S. Not even close
That must be a new record. ; )
Thanks in advance, Jon
