Problem with servo Hitec
Are Hitec servomotors continuos servos? Can I put them on my boe bot?
http://www.active-robots.com/products/motorsandwheels/hitec-servomotors.shtml
If they are standard servos, how many degrees can it turn?
http://www.hitecrcd.com/products/digital/robotics/hsr-1425cr.html
You can use these in a BOE bot. Note that the splines that stick out of the servo (where you connect arms, wheels, etc.) that Hitec uses are different from the standard that Parallax uses (which are believe are the same as Futaba). I believe this means that you can't (easily) use Parallax wheels with Hitec servos.
As far as I know, none of Hitec's other servos are made as continuous rotation. Of course, most servos can be modified to be continuous rotation.
Standard servos will typically turn through 90 degrees when used with radio control equipment (planes, cars, etc.). Most of them will turn through about 180 degrees when controlled using a microcontroller. There are servos that will turn through more, however. Typically, these have been used for things like winches on RC sailboats. There are also external gear packages that will allow them to rotate through 360 degrees (for example).
This links to the same servo as in your first post, an HS-7985MG. This is not a continuous rotation servo. You could probably a modify it to continuous rotation if you wanted to. But, it's a very expensive servo (they run $95 or so in the US). I would not recommend these servos unless you really, really need something they feature.
I don't think there has been a standard HS-1422CR servo from Hitec that is widely available. The only mention I find of them is one that was specially made by Hitec for Lynxmotion (www.lynxmotion.com). The standard Hitec continuous rotation servo is now the HSR-1425CR, which you can get from numerous places. They run about $13 to $17 in the US.
Be aware, as said before, the BoeBot wheels will not fit on these servos. Different spline size. Parallax Servos are Futaba
Jim
You're right. I had to force a reload on that page a couple times for the whole thing to load. All I saw the first few times was the first servo. Something funny with my connection or something, I guess.
The CBA robot kit uses this technique for its wheels and it works really well. The upside is that you are free to use any servos for your robot and not just those with existing wheels that fit their splines.
