connection with the basic stamp microcontroller problem
I would like to know fi I can connect the propeller Servo controller ( http://www.parallax.com/StoreSearchResults/tabid/768/List/0/SortField/4/ProductID/595/Default.aspx?txtSearch=servo+controller)
to my basic stamp microcontroller and program it in PBASIC.
If yes, wich code should I use?
The Propeller Servo Controller comes pre-programmed with a program that makes it behave like the older Parallax Servo Controller that it replaces. It's possible to reprogram the Propeller Servo Controller, but it has to be done using the Propeller Tool or BST and using Spin and Propeller assembly language. There are other programming languages available for the Propeller, but that's already been the (extensive) subject of other threads.
